Best oil for Escos?
Sure this has been asked before - but what oil do people recommend putting in their cossies?
I've got a YBP that's just turned 80k. Ford recommend 10W40 I think, and I have always used this before, but is that the most appropriate given the higher mileage?
Mark
Mark
Any good quality synthetic of that grade will be fine - just change it regularly
The best (IMO) is Silkolene ProS 10w50, but this is for a car that is used aggressively, as it is VERY shear stable and doesn't degrade at high temps
With that mileage I'd be using a 60 weight, like Millers, when these engines were thrown together the tolerances were nowhere near as tight as todays engines, that NEED a thinner oil a modern engine has around 3 thou bore clearance, the alloy pistons on modern engines, a lot also contain a massive metal inner part and are known as steel strapped, these have a 1 to 1 1/2 thou clearance, the reason for the steel strapping is so they don't expand quicker/more than the bores walls, as they would seize otherwise, this is one reason for thinner oils, another being emissions and economy.
Mobil 1 will be drunk big time, as it thins way too much, Pro S is the best really for normal money, although FUCHS is better, my choice would be SUNOCO RACING if you can get it.
I use pro s as it is easy to get and good price, get mine from matt lewis.
Cool thanks for all the advice. I have been thinking that I was using an oil that was too thin given the mileage - it seems to drink a bit these days.
I'll get something thicker and see how that goes
I've got Mobil 1 Motorsport 15w50 for mine now based on a few recommendations. I couldn't fine Silkolene locally. I'll report back how it gets on but I expect I won't have to top up as often.
Take it back & get 10w50, not from Ford either.
No 2 engines are the same so you have to see what works best for yours.
Personally I wouldn't run 5w40 as it doesn't meet the spec for a new engine let alone one with a few miles under its belt.
deathrider666
Sep 28, 2015 06:12 PM
