Headgasket
My saph been off the road for 7mths and in the first week of motering the headgaskets given up
prob been asked a thousand times but which is the best option for me ?
im on greys and t34 on a stock engine, prob pushing it abit but not realy bothered, the car had a group a gasket fitted by PE just before i bought the car but to be honest i dont think it was done to a v good standard as most things seemed to be loose on inspection....
Not gone completly but noticed a little steam lastnite, was a couple of hours after booking into torques
it sweems to seal itself after 5 mins
will a group a fibre gasket be ok again and standard ford bolts ? should i use arp studs ?
cheers paul
it sweems to seal itself after 5 mins will a group a fibre gasket be ok again and standard ford bolts ? should i use arp studs ?
cheers paul
There is one on rs owners club website brand new victor one Ł100 a1 rally told me head and deck has to be straight but not decked so you will have to check when off mate
Group A or ST Escos will be fine on standard Ford bolts mate.
Ive ran mine like that at 34psi on a T34.63 for ages and it gets hammered within an inch of its life everytime I use it
just had mine done went for the yb0611 and standard head bolts.
if thats the one youre gona go for let me know i will give you the details of the place i got mine from,alot cheper than most places.
I would defo go YB 0611, and I would use ARP stud and nut kit, for people fitting these correctly clearing and checking hole depths there will be zero problems, but the std ford bolts will be fine at that level, many 500bhp + engines using the same gasket.
500+ on a yb0611 lol i wouldent use one on anything over a real 380!
220TC
13
Oct 25, 2004 11:22 PM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
