wot polishing machine to get
hi guys im looking at buying a polishing machine/buff machine but im not sure which one to get. I want a good quality one with the adjustable speed setting but i dont know wots the best make to get. I've seen a lot of people rating the meguiars g220 polisher but wondered if there was anything better out there
the G220 is a very god machine and I have one that I use along with my rotart brilliant for the novice and you wont damage the paint!! another less expensive one to get it the Kestral DAS-6 slightly smaller motor than the G220 but still very capable but is is about £40+ cheaper. If its for a hobby stay away form a rotary polishers! hope this helps.
I've had my Clarke one for nearly 7 years and use it most days,best 100 I ever spent!!!but it is a rotary one and you do need to be careful!!how much are these dual action ones?
A G220 is a DA so would be a step back from a rotary so you would be disapointed. Definately choose the G220 for a first machine though, i have one and it can achieve the results of a rotary it just takes a bit more time and effort
As already posted, you cannot go wrong with the Kestral DAS 6 or Megs G220 for a first machine.
I bought a G220 as my first machine and cannot fault it or the after care from Meguiars.
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
