Emerald ecu for cossie,anyone using them???
As above I have recently been looking into the Emerald K3 ecu,it's reasonably priced and looks quite advanced compared to a P8 or L8 Weber ecu,so it should be given the evolution of electronics nowadays.
Anyway just wondered if anyone has one fitted to their cossie and what they think of it really.
Two drawback I see is that
1.it can only be mapped by Emerald,not a cossie specialist-cossie specialists wouldn't map this ecu.
2.Is it to modern/advanced for a cossie and a bit over the top perhaps?
Any help/views would be greatly appreciated good or bad,just be honest with me,pm me if u don't wish to comment on the thread.
MANY THANKS.Lee.
MANY THANKS.Lee.
Yes it's the ecu Tabetha uses,I have spoken to tab at length about this,sounds really good,as I stated above is it to complexed for a cossie and u can only have it mapped by Emerald then obviously so u r limited with one tuner and not a cossie specialist either,that's what concerns me.
CheeRS.Lee.
CheeRS.Lee.
stay L8...
emerald can be mapped by anyone, not just emerald.
hell, ive had a go at mapping mine
and chip has lol
L8 is better suited in a few ways, firstly because your loom wouldnt have to be changed, and also because there is so much support available for that system. + more
and chip has lolL8 is better suited in a few ways, firstly because your loom wouldnt have to be changed, and also because there is so much support available for that system. + more
FPMSL
Its one of the cruder ECU's out there, especially the mapping software which I could write better than if I was pissed and in a hurry, I cant believe he doesnt just employ someone for a few weeks who knows what they are doing to give him a hand with it! Its fucking shockingly ameteur crap.
The ECU's themselves work ok though once they are mapped, nothing fundamentally wrong with them.
Dave is without a doubt the person who knows them best though as is certainly a good recomendation but he isnt the only one who can do it.
As per spikey though I wouldnt replace an L8 with one, it works great anyway and the only reason to replace an L8 in the first place is get the option to be able to more easily remap it, which if you arent doing it yourself anyway makes it pointless to replace really, unless you happen to be going to a specific tuner who chooses to use something else.
I've got one and I'm very happy with it. Works out cheaper in the long run as Dave's rolling road time is very cheap and I'm constantly changing spec. It's also handy in a light car to have it mapped without a big boost spike, but as said any custom map can do this. It's got some handy gadgets - switchable maps, in gear boost adjustment, coilpack. Not plug and play on a cossie, but fine on my Dax where everything is bespoke anyway.
I thought you could use the oringinal loom using the Emerald K3 ???
Im sure the ecu is 'suitable for boost'???? surely ffs?
Ive been out in Tabs car , all seemed to behave perfectly admitately it wasnt huge boost tho. From memory i cant think why it wouldn,t be good for a cossie turbo reading what is said about on Emerald website.
Can the level 8,s run such good emmisions , as mentioned a million times b4 Tabetha,s engine runs .97 co on large injectors. This must be benifical for the engine and overall running . Im definately considering the switch , i know theres lots of other ecu,s but you get attached with what you learn and im finding it very difficult to see where a k3 will be not worth it. I,m really not too bothered on the tech mapping software etc etc just want a lovely controlled engine , with a few tricks to play with . 3 different maps, sounds awsome to me. What i know abt ecu,s you can write on a stamp by the way , just expressing how i see it. Please tell me different if im wrong ,
cheers mike
cheers mike
cheers mike
cheers mike
Rod for example as one map on his cossie on autronic, and that works for shopping and doing over 200mph and everything else in between.
Unless you are going to reguarly run on different fuel types, why would you need a switchable map?
It would be ok if it was on an ecu where even doing ONE map doesnt make you want to cry when you are mapping it at the shit fucking interface
imagine doing it all 3 times though, id sooner slam my bollocks in the bonnet
Why would you want three maps, so you can use it on your road car, and use it on your track car, and another track car if you're that lucky, to have a different setting for any reason, why buy 3 ecus to do this when one can do this ?
The loom doesn't need changing, the supplied end is about an hours work to put on the original loom, but if your using a 20+ year old loom and expecting it to be relaible with no lecky probelms you may be surprised and wish you had.
Why buy a ecu just because of the name paying over the odds for features you don't even want.
Going from my L6 msd chipped ecu, was like heaven esp at the fuel pumps, I was amazed at the extra off boost power.
I've spoken to lee at length, I don't give a shit what he does.
Although chip knows vastly more than I about this subject, I do no he doesn't know as much as he thinks.
Chip as everyone is entitled to thier opinion though, dave and others don't have problems with emerald mapping.
It wasn't designed for turbo cars where the hell that came from I don't know did they accidentally do the software for it.
The boost control is 10000000% better than my piece of shit L6 with msd chip, though the GGR chip was much better anyway.
I buy them for their features and interface which is why I would NEVER buy a shitty emerald, its terrible, have you EVER mapped a car on anything else? Im guessing not and that all of your comments about the emerald are based purely on the fact that you simply dont know any better as you have utterly no experience of other ecu's?
I,d personally like 2 maps , one for normal road and track use, and one for 95 ron when going to my mums 300 miles away. I,d rather burn the shit stuff to get there tbh. lol at you chip about mapping it, it sounds like a nightmare haha , not my concern though thts what you guys are for lol.
chip it does sound interesting you say tht a level8 does have the ability to be more efficent (if thts what ur saying)
Ok so base idle co,s arent everything i guess but it shows it can refine it nicely. From a customers point of view is it a bad thing the software isn,t up to the standard of others?
What you would want different on the two maps?
Why cant one map be used for both?
L8 has multiple octane switches as standard so you can already do that mate!
Its so annoying, im a qualified software engineer and hence have written stuff like this for a living, so it really is something I know quite a bit about, but sadly whoever wrote that software doesnt!
Well this is true, if you are getting Dave to map it anyway (which is a good idea, he is a VERY good mapper) then its of no concern how its done
Manufactures spend a lot of time on such things, and dont forget that although the YB and economy dont go hand in hand, that ecu is used on a lot of other vehicles too.
The problem with the L8, is that most of the chips out there arent very good, you really need to have YOUR car mapped by someone like Karl who really knows what he is doing in order to get the most out of it.
Emerald can give good results in terms of both economy and power mate, and like I just mentioned, if you arent mapping it anyway then the one really annoying thing aobut it wont adversely effect you personally anyway
i see the point about the 2 maps. I was thinking you,ll have a lower boost setting combined with the ign settings to be more fuel friendly with say 95 ron fuel. Ive never been worried about it but it does state ideas like this on emerald site. Im not keen on 'in car boost adjustors TBH , id rather it set .
I guess a few people will very interested in this thread, so Chip is the ecu 'shitty' from my point of view? Its such a big blow when this is seen being said and can perhaps put people off for no GOOD reason , not havin a digg just purely for the forum , taken to Daves, K3,d you agree thats a good move? Im only putting it across like this as my guess is most people reading this will be non mapping people pretty much just after the result at the end of the day. However i personaly like ALL views but can get tricky sometimes to see through mist and where your at and coming from. Your a top pro mate and 100% take on board what you say.
CheeRS Mike
CheeRS Mike
I was looking forward to your response Chip to the above post .
I was looking for some clarity on the big picture about a subject on the thread!!
Its not the ecu in question its the value your comments bring , almost seems like there,s an issue with this K3 and yourself. As mentioned above you may put people off for no GOOD reason.
Thanks Mike
Thanks Mike
CheeRS Mike
CheeRS Mike
If you want to run 95 ron and then 97+ron it would be recomended for the ecu to have knock control,
As you will not have a clean tank of 97+ and the engine can experiance dett thought this if the map was run for good power on it.
Mark
Autronic has the option on the Scooby and Evo pnp boards and it works very well,
On Vipec the V44 needs a external box and the V88 has it on board.
Mark
