problem with blown/leaking intercooler mk1 rs
Old Mar 6, 2010 | 08:43 AM
rssteve's Avatar
rssteve
Default problem with blown/leaking intercooler mk1 rs
ok first i noticed my intake temps high, checked water levels and the intercooler was empty, so i refilled it then the problems started, under hard acceleration the car begins to stutter at about 3-4k rpm, misses and all sorts, then at junction the cars goes to almost stall. anyway the water seems to be going again from the intercooler, run without water the car seems fine, soon as water is topped up it runs bad. i think there is a leak between the air to water side in the intercooler. has anyone else come across this as i can't seem to makesure it is the cooler thats the problem before buying a new one, any ideas on cost? thanks
Old Mar 6, 2010 | 02:17 PM
RichieST's Avatar
RichieST
You can get them pressue tested, apart from that I don't think there's any other way. Does it steam much from the exhaust?
Old Mar 6, 2010 | 02:20 PM
bazzle's Avatar
bazzle
i have an complete standard setup here, if you need any parts let me know
Old Mar 6, 2010 | 07:28 PM
sir nose's Avatar
sir nose
do these car have intake temp gauges as standard or have you an aftermarket item fitted?
Old Mar 7, 2010 | 01:18 PM
HockeyNomad's Avatar
HockeyNomad
aftermartket,
Scangauge 2 is what most people use to monitor, water temp, intake temp etc
Old Mar 7, 2010 | 01:35 PM
Gaz 88's Avatar
Gaz 88
new over a grand from ford mate,
i have also got a spare one for sale
Old Mar 8, 2010 | 08:20 PM
rssteve's Avatar
rssteve
well it must be faulty cause it runs fine if ran without water. how much these going for second hand then?
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
simonmcf
Sep 22, 2015 08:40 AM
tib2220
Sep 14, 2015 12:33 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
