Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
bench top blasting cabinets any good
Old Mar 5, 2010 | 05:26 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
Smile bench top blasting cabinets any good
has anyone got one besides the size limitations do they produce good enough results .im looking at getting one soon would like some feedback first
regards Dave
Old Mar 5, 2010 | 05:42 PM
nellyscossy's Avatar
nellyscossy
weve got one in our workshop, i,ve just used it to clean the bits off my engine (plenum, throttle body, engine mounts etc) they have come up mint, the sand roughs up the surface so when you paint it sticks like sh*t
Old Mar 5, 2010 | 05:57 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
yup one of the best things i bought,you need a good sized compressor tho
Old Mar 5, 2010 | 06:15 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
thanks guys thats what i wanted to know cheers another question then you say it roughs the surface up is it ok to do mating faces on my manifolds then or should the faces be masked up ?????????
thanks for any advice
Old Mar 7, 2010 | 06:59 PM
cabriolet's Avatar
cabriolet
mask em up fella gaffa tape is the dogs danglies for it thats what the pro s use
Old Mar 7, 2010 | 07:27 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
cheers guys the advice is appreciated
Old Mar 8, 2010 | 09:53 PM
1223456's Avatar
1223456
You can change the surface finish with different abrasive grit, for our blasting we use a 3hp 150ltr 14cfm which is plenty. We could not live without our cabinet, its one of those items you never get round to actually buying, but one you get you will be thinking, where have you been all my life.
Hope this helps
Raj
Old Mar 9, 2010 | 07:37 AM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
Thanks Raj
Old Mar 20, 2010 | 10:20 PM
nuttynil's Avatar
nuttynil
RS nutta
yeah must say a nice bench top or any cabinet the bigger the better really brings alloys etc back to life .go get one
Old May 14, 2010 | 08:32 AM
rich2302's Avatar
rich2302
Just out of interest, what pressure do you set the compressor at when shot blasting?
Old May 14, 2010 | 09:17 AM
1223456's Avatar
1223456
That all depends on the part you are blasting, media being used and the finish you are after.
A good all rounder is 90psi with 1"hose and 60-80 media
The bigger the volume of air being used the easier it is to control, I have a 1/4 " blaster at my unit which is very hard to control, at 130psi it is much less affective than my other 1" system at 90psi!!!
Hope this helps
Old May 14, 2010 | 09:48 AM
smudger068's Avatar
smudger068
partically stealling this thread here but what is best for just general use at home and projects, shot bead or sand blasting thanks
Old May 14, 2010 | 10:26 AM
1223456's Avatar
1223456
We use oxide 60-80 media for pretty much everything part I do and thats for powder coating. Everything we do is taken back further by hand though to give the best finish. This could be achieved by using glass beads or alternative media but in all honesty is too much of a ball ache cleaning the cabinet out each time. You need to consider what you are blasting and what finish you are after. Sorry this isnt much help, feel free to give me a shout on 07894 636 707 if you need any more help and I will do my best.
Raj
Old May 14, 2010 | 01:20 PM
smudger068's Avatar
smudger068
just more of cleaning and removing rust and a dirt, instead of rubbing down fiddly items by hand. then respraying items from there really...i just seen people do it but didnt know what was best to use for a multi purpose use
thanks
Old May 15, 2010 | 09:00 PM
cabriolet's Avatar
cabriolet
glass bead fella
markk
Dec 2, 2021 06:59 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
paceo
12
Aug 4, 2015 08:50 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
