cosworth ecu wiring diagram?
Old Mar 5, 2010 | 03:15 PM
fordsportjay's Avatar
fordsportjay
Default cosworth ecu wiring diagram?
or which wire does what on the multi plug.
just for when i refit the engine into the escort later-seem to remember it being quite straight forward regarding what i need to connect up to live,earth,rev counter etc but its been a long time since ive played about like this!
will prob become obvious when i remove the loom from the sierra later on but thought it may be best to have it to hand on here for reference......
thanks in advance
Old Mar 5, 2010 | 03:38 PM
hog's Avatar
hog
hi jay
i used the pdf from this link
http://www.turbosport.co.uk/showthre...diagram-needed
Old Mar 5, 2010 | 04:18 PM
fordsportjay
just pulled it out of the donor car......
only 5 wires by look of it-1 goes to battery,1 goes to switched live,1 goes to fuel pump,then there are 2 that were spliced into the plug going into the rear of the clocks-presume one is for rev counter-not sure what other one is at mo.
Old Mar 5, 2010 | 04:59 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
six wires
black ign feed
green rev counter
red/blue perm live
black/red fuel pump
brown/white temp sensor
green/brown oil pressure
Old Mar 5, 2010 | 05:05 PM
xr4x4rs's Avatar
xr4x4rs
unless its a 2wd loom, if so then it doesnt have oil light on engine loom
cozmeister's Avatar
cozmeister
More boost Igor!
www.bigturbo.co.uk has everything you need to know.
Old Mar 5, 2010 | 05:12 PM
Some 4wd sapphy didn't have it either, and there are two different colours used for this.
Old Mar 5, 2010 | 05:51 PM
fordsportjay
2wd loom-5 wires.
looks easy enough.......
the escos hasnt got a proper loom as such.
Old Jul 18, 2010 | 09:49 PM
Drupi's Avatar
Drupi
Lloyd thanks ...
DixieTheKid
Jul 23, 2023 10:16 AM
big_Rad
Sep 15, 2017 09:36 AM
jay030787
Sep 18, 2015 07:34 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
