Long stud conversion for a YB
Old Feb 28, 2010 | 10:26 PM
Billy_RS's Avatar
Billy_RS
Default Long stud conversion for a YB
What sort of money should i expect to pay to have this done?
And who should do it?
Old Feb 28, 2010 | 10:29 PM
LHD220Turbo's Avatar
LHD220Turbo
reyland do a nice set of studs which uses a standard socket to install
i think reyland charges around £70 a stud supplied and fitted (pretty sure he uses a machine shop to do the machining to the block)
ps. you'll need a 200 block
peter/jedi's Avatar
peter/jedi
i had it done so long ago i can't really remember but think it was about 350 at a1 rallysport bout 3 years ago...
Old Feb 28, 2010 | 10:35 PM
Billy_RS's Avatar
Billy_RS
Yeah i have a 200 block.
£70 a stud? How many studs lol?
Old Feb 28, 2010 | 10:39 PM
basty's Avatar
basty
6 or 8
Old Feb 28, 2010 | 10:40 PM
peter/jedi's Avatar
peter/jedi
mine has the middle 6 done so thats £420
Old Feb 28, 2010 | 10:45 PM
stu21t's Avatar
stu21t
i paid £300
any machine shop should be able to do it
theyre about £30 per stud to buy
Old Feb 28, 2010 | 10:52 PM
Billy_RS's Avatar
Billy_RS
Originally Posted by stu21t
i paid £300
Where did you get them from mate?
Old Feb 28, 2010 | 11:05 PM
PAUL V's Avatar
PAUL V
This is the place that mountue use they will make the studs for you and machine the block.
http://www.pmasonengineering.co.uk/
Old Mar 1, 2010 | 12:18 PM
M K's Avatar
M K
if you get a quote from the company in maldon then let me know the price for 6 long studs and the machining
Old Mar 1, 2010 | 12:21 PM
Mike Kerbey's Avatar
Mike Kerbey
I have 6 long studs and it cost £420 from a place called gosnays in essex
Old Mar 1, 2010 | 02:15 PM
Billy_RS's Avatar
Billy_RS
Anyone else?
Old Mar 1, 2010 | 04:25 PM
Billy_RS's Avatar
Billy_RS
Old Mar 3, 2010 | 02:05 PM
M K's Avatar
M K
i have emailed pmasonengineering in Maldon for a price to machine the block for and supply 6 long studs with washers, o'rings and nuts,
will let you know what they say
Old Mar 3, 2010 | 02:30 PM
Billy_RS's Avatar
Billy_RS
Ok cool, see if they will do a deal on 2 engines?
Old Mar 4, 2010 | 12:31 PM
M K's Avatar
M K
just got a price and there bloody cheap compared to anyone else, just waiting for them to confirm something then il put the price up for anyone interested
Old Mar 4, 2010 | 01:27 PM
stu21t's Avatar
stu21t
If that's maldon Essex, I guess that's who did mine.
I had them done as part of the rebuild by joe Stevens @ bluesprint, and he's also in maldon.
Old Mar 4, 2010 | 01:52 PM
Billy_RS's Avatar
Billy_RS
Yeah put it up or send me a PM if you want to keep it quiet?
Nice one fella
Old Apr 6, 2010 | 10:28 PM
Danny @ Enhanced Performance's Avatar
pete mason engineering is where most of joes blocks go for long studding and as said are the same firm that do all mountunes long studding etc
ps you wont be able to get just any engineering firm to machine block for long studding..
cheers danny
Old Apr 10, 2010 | 09:46 AM
M K's Avatar
M K
price from pmason engineering,
Price to M/C Block for 6 Studs = £85.0
Stud Kit Complete = £130.0
Old Apr 10, 2010 | 09:49 AM
KSA-Cossie's Avatar
KSA-Cossie
Mine was done by SCS
Old Apr 10, 2010 | 10:14 AM
andy escos's Avatar
andy escos
thats a very good price how much for ten with the modified water pump
Old Apr 10, 2010 | 10:26 AM
Turbosimpsons's Avatar
Turbosimpsons
wow. that sounds cheap. how bout a group buy.
Old Apr 10, 2010 | 11:57 AM
markk's Avatar
markk
more a question is do i need to have long studs ?
Old Apr 10, 2010 | 02:28 PM
Turbosimpsons
[quote=markk;4842853]more a question is do i need to have long studs ?[/quote
depends how much horse. you wana run
Old Apr 10, 2010 | 02:30 PM
Turbosimpsons
do they do wet liner conversions. if so how much
Old Apr 10, 2010 | 03:22 PM
Ima Racing's Avatar
Ima Racing
...you can use std headbolts at 600bhp so long studding isnt essential BUT i feel its better to have when using the WRC head gasket to get the clamp. If your running high comp then it is essential imo.
Old Apr 10, 2010 | 07:43 PM
id love to see how long a yb running 600 bhp with out long studs would last!!!!
if your building a big spec yb why wouldnt you make it better for the cost of long studding???
the clamping forces are better and come from the base of the block instead of the deck much safer and stronger....
cheers danny
Old Apr 10, 2010 | 08:57 PM
Ima Racing's Avatar
Ima Racing
It would last fine mate on a low comp engine, hi comp ala wrc cars and high cylinder pressures are where u really need long stud!
Old Apr 11, 2010 | 12:44 AM
Absolute bollox mate!!!
cheers danny
Old Apr 11, 2010 | 09:15 AM
Ima Racing's Avatar
Ima Racing
cheers danny
..oh not to forget the 3bar boost spike!
The NMS monster runs std head bolts i beleive...that has a lot of bhp lol.
Its called "wrc" longstudding for a reason and thats only 300bhp with massive torque massive boost spike 9-1 + comp.
Old Apr 11, 2010 | 07:24 PM
why do you think ford desighned a thick wall block back in the early 80s for??
The bttc cars(rs500)had a thick wall block wich could be drilled for long studding and big power upgrades,and funnily people and race teams did this to good effect
What power were these phil you numpty???550 bhp+ with what cr???6.8 and evenlower iirc
so as i said your talking shit mate!!!!
long studding was here before any body even thought of high comp engines and has nothing to do with power but boost pressures to stop the heads moving around on the block hence why they still use them on the wrc yb engines...
Also it was grp a long studding first so wrong again...
cheers danny
Old Apr 11, 2010 | 07:33 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Phil,
I am concerned about my eninge at 480 bhp and no long studs!. Let alone 600.
Old Apr 11, 2010 | 07:54 PM
Originally Posted by CossieRich
Phil,
the thing is it may be fine but with all that boost you run the head will be moving around on the block and sooner or latter it will crack the block face and if the hg does goe it will make a bigger mess than if studded as the std head bolts loosen before the hg starts to leak badly and can cause detting,its all ifs and buts but hey ho it works now just worry about it when it goes wrong...
cheers danny
Old Apr 11, 2010 | 08:00 PM
CossieRich's Avatar
CossieRich
Danny,
My engine was fine with 2.5 bar peak boost from a t34 but 2.5 bar froma Gt30 is another matter which is why i am slightly concerned . But yes you are correct its all ifs and's and but's. Will worry if it starts to go wrong
Old Apr 11, 2010 | 08:09 PM
james kiely's Avatar
james kiely
cheers danny
can you retorque the headbolts danny, or is it possible to replace the headbolts without removing the head ?
Old Apr 11, 2010 | 08:17 PM
thats a good one..if you mean the long stud nuts then yes we always re torque them after the first hot run,if you mean std ones then you can always chek the torque settings as for changing them without removing the head you can change them one at a time using the torque pattern with out any trouble,just dont undoe them al at once as the head will lift and put fluids in the cylinder
cheers danny
Old Apr 11, 2010 | 08:22 PM
james kiely
yes thats what i meant danny ,if you checked and the bolts had lost their torque setting could you change them one a time using the original settings.
it could save a lot of hassle maybe?
Old Apr 11, 2010 | 08:52 PM
STUCOS's Avatar
STUCOS
Last time i got a block done,it was by a guy in blackpool,recomennded by msd,cost £200 and i supplied my own long studs,doing it again i would get 10 studs done
cheeRS stu
Old Apr 11, 2010 | 09:08 PM
saph4be's Avatar
saph4be
danny just in case your interested here is what NMS explained why they disagree with long studding
https://passionford.com/forum/genera...dding-bad.html
