focus 1.6 16v blowing bateries
Old Feb 25, 2010 | 02:33 PM
towncruiser's Avatar
towncruiser
Default focus 1.6 16v blowing bateries
hi i have a petrol focus and the bateries dont last any one have a idea why it is doing this
or where i should start looking?
Old Feb 25, 2010 | 07:05 PM
JamesXP's Avatar
JamesXP
You getting the proper silver calcium batteries?
Old Feb 25, 2010 | 09:27 PM
MisiekT_PL's Avatar
MisiekT_PL
check electrics - you might have a problem with an alternator or any other thing - and the battery is simply not charged properly when driving
Old Feb 25, 2010 | 09:34 PM
smoothy582's Avatar
smoothy582
as said before make sure the bats are silver calcium because if there not the smart charge alternator wont know what its doing, if you are using the correct bat you will need to get the smart charge system checked and reset, and a word of warning you should never jump start any new ford as these systems can go upto 18v
hope this helps rich
Old Feb 25, 2010 | 09:39 PM
RichieST's Avatar
RichieST
What do you mean by blowing batteries?
Old Mar 4, 2010 | 03:30 AM
towncruiser
how do i know if its one of those?
Old Mar 4, 2010 | 06:15 AM
bythomson's Avatar
bythomson
sounds like over charging alternator dont know ho to check but there will be spikes in the volts that blow the battery and if so its a new regulator easy fix tho quite simple to replace but try the right battery first
Old Mar 8, 2010 | 05:15 PM
towncruiser
tested alternator its charging at 14.5 volts
Ian1964
12
Jan 26, 2021 11:57 AM
liamT74
Sep 23, 2015 10:24 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
