ka engine problems
Old Feb 24, 2010 | 07:54 PM
dan1976's Avatar
dan1976
Default ka engine problems
hi all my ka 1.3 1998 has rough running problems when its cold it runs like it has no choke and struggles to accelerate when its warm it idles ok but when you accelerate it feels like your bouncing up the road and somtimes hesitates.
With the bonnet open and moving the throttle a little you can hear a air sucking sound
please any help apprecated
Old Feb 25, 2010 | 06:24 AM
oldford's Avatar
oldford
Find the place where you hear the sucking sound and repair this leak.
If you spray brake cleaner around the suspected leak you can hear the engine rpm's change when you spray directly onto the leak.
Old Feb 25, 2010 | 03:04 PM
As said does sound like a running lean problem, so fix any leaks first.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
