Who's Running a coilpack on there cossy?
http://www.randbmotorsport.co.uk/shop/Gallery.asp
Click on the photo of my engine and you will see it behind the fuel regulator bolted to the plenum. It has to be somewhere dry....
You are welcome Rayn (sic)
I thought I would point this out as I have seen loads of people install it behind the scuttle where it gets full of water and causes the misfires that it is designed to cure by getting rid of the dizzy
i think lee had it hidden on the inner wind didnt you lee?
as i was trying to see where you had put it, as i was trying to copy you
but have got a decent picture of you bay to go by.
Need to know now, as im doing my loom as we speak, and wondering how long i should make the 3 wires and where i should branch them off the main loom
cheers mate
sorted out the wiring so i've made it long enough to go pretty much anywhere on the right hand side of the bay!
Cheers for all the info.
Can braid this bit or wiring now
bigluke200
14
Sep 2, 2015 10:35 PM
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
marky_g
Aug 15, 2015 10:43 AM
