Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Brake Pipe Bending Tool
Old Feb 18, 2010 | 11:25 PM
Simmo's Avatar
Simmo
Default Brake Pipe Bending Tool
Does anyone know of a small radius pipe bender to replicate the bends of original brake pipes?
I've got one of the normal ones a bit like this... http://cgi.ebay.co.uk/3IN1-COPPER-PI...item414d1795c0
...but when doing say a 90deg bend the actual radius is bigger than the std pipe. It's not a major problem it'd just be nice to make them spot on!
Old Feb 19, 2010 | 09:31 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
the one u show is good for larger bends but these are good for smaller bends http://cgi.ebay.co.uk/Pipe-Bending-P...item45ed9cdaa9
Old Feb 19, 2010 | 04:11 PM
Simmo's Avatar
Simmo
Thanks for that
Also found this as well (not sure how they compare?)... http://www.demon-tweeks.co.uk/produc...code=S/C000160
...no idea why i didn't come across those before!
Old Feb 19, 2010 | 05:48 PM
ajamesc's Avatar
ajamesc
never seen one of them should do the job if they say it will have used the type u have and the one i showed that one on ebay is a good little tool easy to use to with copper pipe anyway harder with steel
Old Feb 19, 2010 | 06:17 PM
Simmo's Avatar
Simmo
Just the job i'll get one of those then!
Cosnada
Jan 7, 2016 05:30 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
mpilk
Sep 27, 2015 09:21 AM
