Brake Pipe Bending Tool
Does anyone know of a small radius pipe bender to replicate the bends of original brake pipes?
I've got one of the normal ones a bit like this... http://cgi.ebay.co.uk/3IN1-COPPER-PI...item414d1795c0 ...but when doing say a 90deg bend the actual radius is bigger than the std pipe. It's not a major problem it'd just be nice to make them spot on! :top: |
the one u show is good for larger bends but these are good for smaller bends http://cgi.ebay.co.uk/Pipe-Bending-P...item45ed9cdaa9
Thanks for that :top:
Also found this as well (not sure how they compare?)... http://www.demon-tweeks.co.uk/produc...code=S/C000160 ...no idea why i didn't come across those before! :oops: |
never seen one of them should do the job if they say it will have used the type u have and the one i showed that one on ebay is a good little tool easy to use to with copper pipe anyway harder with steel
Just the job i'll get one of those then!
:top: |
© 2024 MH Sub I, LLC dba Internet Brands
