Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Escort MK6 1.8 Si Question
Old Feb 18, 2010 | 09:35 PM
Phil_si2000's Avatar
Phil_si2000
Kiss My RS!!
Default Escort MK6 1.8 Si Question
i've now got a Mk6 1.8 si again, this is my third in total, last one only lasted 6 days! but i had the 1st one about 2 years, my question is about the rear brakes and wheel bearings, on the first one i had real problems with the rear wheel bearings going all the time and its started again on this one i've got now, i want to know if there are any other ways, besides an RS2000 rear disc conversion that i can put rear discs on my escort, this may sound a bit weird but i believe if i have discs on the back it shouldn't go through wheel bearings quite as much? any help or any ideas on how i can solve this problem would be greatly appreiciated,
cheers
Old Feb 18, 2010 | 09:39 PM
liam-rst's Avatar
liam-rst
shit happens
i ant see rear disks making any difference in the bearing failures, all i can think is that your over tightening them
Old Feb 18, 2010 | 09:44 PM
Phil_si2000
Kiss My RS!!
is there and specific tightness that they should be tightened to? i'd never really thought of that but tbh i never really used to overtighten them in my opinion, then again i cudda been if you know what i mean, lol
Old Feb 18, 2010 | 09:47 PM
liam-rst's Avatar
liam-rst
shit happens
yh id have to look in my manual to tell u it tho bit iirc its surprisingly low, ive never had trouble with rears an i got a escort gti which is same, if u over tighten them it will munch through them, also wot size wheels u got coz that can affect them
Old Feb 18, 2010 | 09:50 PM
Phil_si2000
Kiss My RS!!
on this one i've only got 16's, on my first one i was swapping and changing between 15's and 17's, i'll find out what they want tightning to and try changing them both and see how i get on, cheers for the info/help
Old Feb 18, 2010 | 09:53 PM
liam-rst's Avatar
liam-rst
shit happens
no worries m8, buy a manual, for 20 quid well worth it just for lil jobs like that, an make sure u lube bearin properly too,
good luck
Old Feb 19, 2010 | 08:17 PM
rodney,.'s Avatar
rodney,.
its a simple problem wit the wheel breaings , the rear spindles wear out to the point where even if you putnew bearings there will still be play in them and they wear really fast , all you need to do is buy new rear spindles and all will be fine again,.
Old Feb 19, 2010 | 08:23 PM
botters's Avatar
botters
competant bodger
+1
Old Feb 23, 2010 | 07:31 PM
Jamie200's Avatar
Jamie200
its a simple problem with the wheel breaings , the rear spindles wear out to the point where even if you put new bearings there will still be play in them and they wear really fast , all you need to do is buy new rear spindles and all will be fine again,.
+2 from experience, the spindle shouldn't wear at the bearing as the inside of the bearing doesn't spin on the hub. I found the seal in the drum had worn a groove in the spindle letting water/dirt etc inside, damaging the bearing and I'd begin to hear the dreaded rumbling.
They are around £65 each from Ford.
Vincereese
Jun 1, 2023 09:14 AM
Kyle Langford
27
Aug 5, 2019 07:54 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
