Rst fuel issue.
Old Feb 17, 2010 | 11:50 AM
Chopshop85's Avatar
Chopshop85
Default Rst fuel issue.
I have been helping a friend drop an RST lump into his mk4 cabby. However, everything is in place and there is no fuel pressure between the metering unit and the injectors?
The engine was runnning fine in the rst it was in a few months ago. There is fuel pressure up to the metering unit, but nothing after?
Anyone have any ideas on certain faults with the metering unit that could cause this?
cheers.
Old Feb 17, 2010 | 01:58 PM
essexRSTSouthend's Avatar
essexRSTSouthend
The fuel regulator could of packed up.You sure you not got any leaks or smell of fuel?
Old Feb 17, 2010 | 03:29 PM
Try pushing down the metering flap when you spin it over, this will open the valve inside to let fuel out, might just be a bit sticky/gummed up, if so spray plate and edges with carb cleaner.
Old Feb 17, 2010 | 08:15 PM
djchurch2001's Avatar
djchurch2001
did you change the tank and fuel pump, the RS runs alot higher pressure. If the MK4 cabby was running EFI management then the fuel pump would not work with the RS engine.
Old Feb 17, 2010 | 10:43 PM
Chopshop85's Avatar
Chopshop85
Everything has been swapped over. Fuel lines, tank, pump the lot.
Have tried pushing the flap as tabetha suggested but still no luck.
The fuel is coming through the metering unit, but only a slight dribble compared to what it should be.
I think essex might be onto something with the regulator tho?
timsrs
Nov 13, 2018 11:48 AM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
