Fiesta engine help!!!
Old Feb 13, 2010 | 07:20 PM
tim_bisley77's Avatar
tim_bisley77
Default Fiesta engine help!!!
Hey, engine went bang in my mark 4 fiesta the other day, 1250 zetec. So i swapped it out for another one using the cars original ecu and everything cos the engines are the same. I can now not get a spark, any ideas??? Really stuck now, jus wanna get it sorted asap...
Old Feb 13, 2010 | 07:40 PM
Is it a chipped key, ie did you use the other iggy lock and key if it is ?
Old Feb 13, 2010 | 09:41 PM
tim_bisley77
No, i've never swapped anything with an immobiliser before; bit of a learning curve!! There seems to be no spark or fuel or anything. It turns over but thats it... Immobiliser, what do i need off the donor car??
Old Feb 14, 2010 | 02:26 PM
If it is an immobiliser issue with a chipped key used on the car from which the ecu came, then it won't work without the correct key being recognised, they do usually turn over but no sparks and no fuelling.
It may be this, need to look at key on other car, or for a ring around the ignition switch used for detecting the code of the key where used.
If not this it may be just something you've missed connection wise.
Old Feb 14, 2010 | 10:05 PM
tim_bisley77
right, had another look today. Don't think its an immobiliser issue now. Definitely getting fuel, but not even a sign of a spark. All connections are okay, checked and double checked and triple checked... It appears that the wiring might be different. I've put a p reg engine into a t reg car, it would appear the only thing left to do is to swap the loom, this looks a bit of a nightmare. Am i missing something obvious?? Anybody got any insight on changing the loom..
JoeyBoyden
Jan 4, 2024 02:36 PM
Ben26
Aug 27, 2015 08:56 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
