2.1 16v Zetec turbo (now with compressor map)
Old Jan 7, 2005 | 09:24 AM
Rossco's Avatar
Rossco
Default 2.1 16v Zetec turbo (now with compressor map)
Right thinking about using a GT turbo, iam after about 220-240bhp from the engine, with as little lag as possible, what do you guys think about this?
Garrett GT22 Turbo
Compressor Trim/Hsg: 60 Trim (0.51 A/R). Turbine Housing: 0.67 A/R (Wastegated).
Says it will suport 280bhp.
Thoughts please
Ross.
Old Jan 7, 2005 | 09:27 AM
CabrioTurbo's Avatar
CabrioTurbo
thats quite a big exhaust housing... although with the 2.0l engine and the fact that its a GT it should be fine.
if you were after minimal lag you might want to consider a .48 housing but this will run out of puff higher up the revs if it was me i would go for the one you have looked at..
How much are they out of intrest?
Old Jan 7, 2005 | 09:33 AM
B19-TRB's Avatar
B19-TRB
Originally Posted by CabrioTurbo
higher up the revs
Its a zetec there is no higher up the revs!
Old Jan 7, 2005 | 09:34 AM
M Brian's Avatar
M Brian
to support 280 max sounds a little bit wasted on a 2.1 zetec turbo
is it going to be easy and straight forward fitment? surely stage 3 t3 or something be equivalent, cheaper and more straightforward to fit??
just a thought. interested in costs and specs for the GT turbos on zetecs though
Old Jan 7, 2005 | 09:36 AM
Rossco's Avatar
Rossco
The smallest exhaust housing they do is .56 and that is not wastegated, meaning more headakes of an extenal wastegate.
Price wise under $800 delivered to your door, so about Ł400
Old Jan 7, 2005 | 09:41 AM
Rossco's Avatar
Rossco
Fitment should not be anymore of a problem than a T3 as iam using a Focus exhaust manifold so its having an adapter plate mate anyway
Price wise as above mate
The T3 ive got is standard and will probally need a rebuild anyway costing around Ł500, so thats why iam thinking about the GT, that price is outright to, so can sell the T3 to someone who wants one for exchange
Ross.
Old Jan 7, 2005 | 09:49 AM
JAP CRAP's Avatar
JAP CRAP
My thoughts are that you should hurry the fuck up and get it finished, stopping only breifly to fit my rad when I get it and paint my car too
Old Jan 7, 2005 | 09:53 AM
Rossco's Avatar
Rossco
Get your rad and ill put it in for ya mate, can do it sat morning if you like?
I will be on double time though coz iam ill!!!! (Ł2ph insted of my normal Ł1ph)
Can do it sat if you want though?
Old Jan 7, 2005 | 09:54 AM
CabrioTurbo
a stage 3 T3 will be shite compared to that GT.
Is it just the lag reason (and bling factor ) that you want a GT series turbo.. cos unless you have special plans for the engine you may be better going for a T34 easy as to fit and can still have fairly minimal lag. arround Ł250-300 from the states inc internal wastegate and 300Hp+ capabilities!
CheeRS
Phil
Old Jan 7, 2005 | 10:04 AM
Rossco's Avatar
Rossco
Yeh its mainy the LOL (lack-o-lag) i want. Fitting aint a problem as iam not using the RST manifold anyway.Iam never going to get near 300bhp as iam using standard Zetec rods.
Old Jan 7, 2005 | 11:11 AM
Boostboy's Avatar
Boostboy
ive done the 16v and got stage 3 t3 and isnt laggy at all that should make plenty
of boost for what u want mate!
makes boost bout 2500 rpm!
Old Jan 7, 2005 | 11:23 AM
JAP CRAP's Avatar
JAP CRAP
Ross.
dont actually have a rad yet. the guy with the cossie, which is at LPS has sold his already Thanks for offering your services I shall take you up on the kind offer when I source a rad
RE the turbo.
You dont actually need to ask this question do you! you know damn well you want a GT turbo so all this talk of T series is a waste of time. All you need to know is which is the best GT series for minimum lag with say 300bhp limit or something.
Why dont you call the turbo company up. say you have a 2 litre engine, it will be on 98 Ron fuel, you want 250bhp, minimum lag, gt turbo what do they suggest. failing that, find a couple you like, get the compressor maps and ask Mike to see what he thinks.........
Old Jan 7, 2005 | 11:38 AM
Rossco's Avatar
Rossco
Check you, nearly sounds like you know what your on about there!!
Think the compressor maps are on the site..........
One compressor map:
Old Jan 7, 2005 | 12:23 PM
M Brian's Avatar
M Brian
thats what i was saying earlier I think.
smaller A/Rs but bigger turbo more flow
as can be seen red against blue.
correct me if im wrong
also --- why is that GT soooo much better than say a stage 3 T3? (is stage 3 .48 or .63 btw??)
Old Jan 7, 2005 | 12:28 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Rossco, what boost are you planning to run? And what is your planned RPM redline? That way you can WORK OUT which turbo will be best for your needs
Old Jan 7, 2005 | 12:38 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You sure?? How about Import Tax, VAT and Courier Customs Charge?? That would take it over Ł500.
Old Jan 7, 2005 | 12:51 PM
Red16's Avatar
Red16
the stage 3 t3 i bought had a 0.63
Old Jan 7, 2005 | 04:20 PM
Rossco's Avatar
Rossco
Iam gonna be using standard rods, so 16-18psi i should think, should be safe then, to start with iam gonna try standard cams and see how they go, not really sure on the redline rpm?? (Help me please, iam just a dum paint sprayer )
Depends how it enters the country, if you no what i mean!!
Old Jan 8, 2005 | 03:59 PM
Rossco's Avatar
Rossco
Any more help advice please
Thanks
JoeyBoyden
Jan 4, 2024 02:36 PM
robnock
21
May 13, 2019 05:29 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
