thermo time switch on mfi
Old Feb 10, 2010 | 04:15 PM
luxembourgrst's Avatar
luxembourgrst
Default thermo time switch on mfi
hy i need a new multi plug for my brown thermo switch there are 2 cables can i connect them how i want on the thermo switch sensor ?
and my escort rs turbo from 88 d ont want to start when the engine is hot
i heart that the thermo switch its only there to active the cold start ingector the blue plug ....
thanks
Old Feb 10, 2010 | 06:30 PM
Rob_DOHC's Avatar
Rob_DOHC
You can get the connector from ebay, you may still be able to get the sensor from ford?....
Old Feb 10, 2010 | 06:34 PM
XR2's Avatar
XR2
Thermo switch controls more than just the cold start injector. On n/a MFIs, it controls the cold start injector and the fuel shut off. In KE-Jets the ECU also gets the temperature from the sensor (it isn't a switch then) to control amount of fuel. So it should be connected correct to cure your hot/cold start problems.
Old Feb 10, 2010 | 06:38 PM
Rob_DOHC's Avatar
Rob_DOHC
Im pretty sure the sensor/switch for the cold start valve is only used for the cold start valve, it has a small heating element in it and a bimetallic spring, which can fail.
You may be referring to the engine coolant temp sensor or the air temp sensor.
Rob,
Old Feb 10, 2010 | 06:57 PM
luxembourgrst
well only for the cold start injector or also for other things?
Old Feb 10, 2010 | 07:12 PM
Rob_DOHC's Avatar
Rob_DOHC
what?
Old Mar 7, 2010 | 05:49 PM
luxembourgrst
where can i find a thermo switch sensor i d ont whant to go to ford
thanks
Old Mar 26, 2010 | 11:09 PM
rambo84's Avatar
rambo84
did you find a thermo switch? im looking for one at the moment and ford cant get them and bosch dont make them anymore, let me know if you found one and it solved your problem, cheers
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 15, 2015 10:43 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
