Allison gearboxes ?
Old Feb 8, 2010 | 10:34 AM
B16JUS's Avatar
B16JUS
Default Allison gearboxes ?
anyone here work on them or know anyone who does ?
got a auto box in a fire engine with a problem that need fixing and dont want to pay what allison charge
J
Old Feb 8, 2010 | 12:39 PM
stuartrsturbo's Avatar
stuartrsturbo
We use HL Smith (01902 373011) when we have problems with gearboxes. They might be able to help out. I work the parts dept for a truck garage.
Old Feb 8, 2010 | 12:40 PM
nickywarwick's Avatar
nickywarwick
whats the problem that needs fixing? symptoms? were you at?
Old Feb 8, 2010 | 12:43 PM
STUCOS's Avatar
STUCOS
Allison g/boxes dont usually give problems,is it in a scania fire tender,can you give me the faults,and any fault codes you can get out of the display
cheeRS stu
Old Feb 8, 2010 | 12:46 PM
nickywarwick
^^^^ same if its in a volvo mate give get fault codes etc
Old Feb 8, 2010 | 01:07 PM
B16JUS's Avatar
B16JUS
its a 1987 dennis ire engine, gearbox is a mt643
goes up the gears fine but comming down it seems to go into 1st far too early approx 9mph all the others go into 1st when literally stopped approx 1mph
its too early for error codes etc
cheers
J
Old Feb 8, 2010 | 04:31 PM
I've used JOHN LOVEGROVE of ATP Transmissions in Bristol before, never found a thing they couldn't do auto wise, did me a cracking modded ZF4hp22 with 24 components from a rangey converted to 2wd with 850 bmw tail end, pricey but took the abuse no problem, serious amount of mods to it as well as above.
Old Feb 8, 2010 | 04:40 PM
B16JUS's Avatar
B16JUS
ok great i will give them a call cheers
Old Feb 8, 2010 | 04:55 PM
stuartrsturbo
did you try HL smith?
Old Feb 8, 2010 | 04:57 PM
B16JUS's Avatar
B16JUS
yes spoke to a guy called john really helpful have me a list of things to check to eliminate first, he doesnt think its the box its something silly which controls it.
fingers crossed its a air leak or something sticking
Old Feb 8, 2010 | 07:35 PM
chink's Avatar
chink
i used tp work on alison gearboxes for buses at a place called queensbridge psv in wakefield forgot number. been a few year now but seems like governor is sticking may be wrong
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
