focus -Heater Stopped
Old Feb 7, 2010 | 05:27 PM
ukste1349's Avatar
ukste1349
Angry focus -Heater Stopped
Foucs T reg 1999 1.8
Heater Stopped working completely No power at any numbers.
A/C Light still coming on when you press it.
Sounds coming from heater motor when you turn heat direction switch.
I have taken off the resistor pack and all looks ok, is their any tests I can do on it?
Does this sound likee it is a resistor fault or somthing elese?
Old Feb 13, 2010 | 02:25 PM
ukste1349's Avatar
ukste1349
updat.....
got a brand new replacement Resistor 100% checked.....attached it to blug under dash still nothing worked.
when I took the resistor back out of glove box I knocked it agains the metel under the glove box and a spark shot off it then the motor started to blow cold air.
I moved the resistor away from the metal and the motor stopped blowing.
anyone got any ideas please.....this car is driving me mental!!!!!!!
Old Feb 13, 2010 | 09:42 PM
pdfbt40's Avatar
pdfbt40
The resistor pack and switch are on the ground side of the blower motor circuit.
Touching the resistor pack against metal will provide a ground for the current needed by the blower motor.
Have you checked the switch itself? They are know to fail so a ground is not available for the motor. Hence no running at any position, unlike the resistor pack (thermal fuse failure) 1-3 not running.
Martin
Fudgey
Sep 17, 2015 01:06 PM
talon1
Sep 15, 2015 10:27 AM
JamboRS
28
Sep 14, 2015 09:02 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
