not starting
Old Jan 26, 2010 | 06:39 PM
mike s2 rst's Avatar
mike s2 rst
Default not starting
spend the weekend getting everything back together under my bonnet.filled with oil and coolant took the plugs out to crank it afew times to get the oil pressure up as the engine hasnt been run yet since the build but it wont crank! all i get is a click from the starter area!sounds like a relay clicking?im worried that i may have the wiring to the altenator crossed with the starter does someone have a wiring diagram so as i can trace/check my wiring??
Old Jan 26, 2010 | 06:54 PM
Rob_DOHC's Avatar
Rob_DOHC
The starter solenoid will make that noise. Either the starter in not engaging and closing its contacts or your started has no main feed from the battery.
Rob,
Old Jan 26, 2010 | 07:14 PM
mike s2 rst
the starter has got its main feed from batt and is getting good voltage.because i can hear the starter clicking im guessing the signal is good so im gona rip the starter off and bench test it 2moz!it was working ok before and is fairly new but you never know!
im praying it starts!!
Old Jan 26, 2010 | 07:59 PM
studabear's Avatar
studabear
can the engine be turned over by hand?
Old Jan 26, 2010 | 08:15 PM
mike s2 rst
yea its only just been rebuild!hasnt been run yet
Old Jan 26, 2010 | 08:29 PM
project rs's Avatar
project rs
have you actually turned it by hand though since you re-assembled everything as i had similar problem a couple months ago with a fresh engine too
Old Jan 26, 2010 | 08:52 PM
mike s2 rst
yea iv turnned it over loads!didnt want it to seize!and to spread the oil.carried out compression test and cylinder leak test when it was at work.its all timed up and got good compression!so fingers crossed theres no reason why it shouldnt run!!
worryingly i build engines loads at work!!!and as a side job!!this is my first ford tho!!
Old Jan 26, 2010 | 09:02 PM
project rs's Avatar
project rs
battery got enough charge in it, sorry it sounds daft but sometimes we over look the obvious(spelling)
Old Jan 26, 2010 | 09:18 PM
mike s2 rst
yea new batti dont mind suggestions!iv prob missed something simple!!iv got loads of pics of the engine build i was gonna stick them in the restro section!
Old Jan 26, 2010 | 09:42 PM
liam-rst's Avatar
liam-rst
shit happens
just sounds like a starter m8 tbh, if they been sittin for a while they can jamb up, just give it the ol technical tap with a hammer an see if that helps
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
