1 owner from new, original Escort RS Turbo
Old Jan 24, 2010 | 04:41 PM
TorqueTerrorist's Avatar
TorqueTerrorist
Audi 2.0T FSI
Default 1 owner from new, original Escort RS Turbo
Hello all,
My boss has just brought an original, 1 owner from new RS which is unbelieveable in the flesh! This thing is mint which is even more of a suprise as it was owned by a mature lady who really wasnt in to cars in the way most of us are on forums.
Anyway, apart from 1 problem its perfect! The problem is when warmed up it doesnt want to run properly, almost like its overfuelling i guess and runs like a dream when cold. I had one years ago and remember some sort of cold start valve problem!? Is this the case or possible sensor issue?
I want to help him as i had many a CVH turbo lump in and out of my cars, rebuilt them etc. Just want to know for sure which path to go down first!
Thanks in advance, kind regards Craig
Old Jan 24, 2010 | 05:42 PM
Rob_DOHC's Avatar
Rob_DOHC
Doesn't sound too much like a cold start valve issue but its probably 20 odd years old now, so could do with a set of new sensors and a set up (even if standard boost is kept). Unfortunately the mfi unit tends to fall out of adjustment after a while, as parts age etcetc.
Sounds like a sensor problem to me any way
Rob,
Old Jan 24, 2010 | 05:48 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
disconnect the cold start on the under side of the plenum, may help, usually i find its the sensor at fault tho
Old Jan 24, 2010 | 05:50 PM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Any pictures?
Old Jan 24, 2010 | 05:53 PM
Rob_DOHC's Avatar
Rob_DOHC
The cold start valve is there for a reason. But it may help you to diagnose a fault. I think a coolant temp sensor may be at fault, thinks it too cold etc.
Old Jan 24, 2010 | 05:58 PM
RUPERT THE BIG HAIRY BEAR's Avatar
pics or stfu
Old Jan 24, 2010 | 06:14 PM
TorqueTerrorist
Audi 2.0T FSI
I will try and get some pics. So temp sensor, cold start valve perhaps first port of call?
Old Jan 24, 2010 | 06:24 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
could be a couple of things, stop guessing and take it to someone who knows how the fuel system works!
Old Jan 24, 2010 | 06:40 PM
jonny s2's Avatar
jonny s2
if your not sure what you are doing,and keep guessing changing parts this would cost more than sending it to someone in the know,these are 20yr old cars which need propper attention, now pics please ive got to see
Old Jan 24, 2010 | 09:06 PM
Oranoco's Avatar
Oranoco
You have SCC PErformance based in St Albans. Rob and co are more than slightly versed with RS Turbo's. Hey they were key in the build of mine. 01727 867747
Old Jan 24, 2010 | 09:46 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
To see, whether it's running rich or lean take the air filter off to gain access to the flap in the metering unit. When it's warmed up and running like a bag of nails, slightly press down the flap. If it gets worse, the car is indeed overfueling. If it runs nicer, it was running lean.
Fur further reference check out this link:
http://www.porsche924-944.nl/924/Tro...#warm%20engine
Old Jan 25, 2010 | 07:28 AM
Rob_DOHC's Avatar
Rob_DOHC
Peter good point! But by press the flap i think you should read: lightly touch the flap, you should not move it by more than a few mm or the engine will go rich and die any way.
Rob,
Old Jan 25, 2010 | 08:11 AM
user 7082039239
Originally Posted by Rob_DOHC
Peter good point! But by press the flap i think you should read at lightly touch the flap, you should not move it by more than a few mm or the engine will go rich and die any way.
Yep, sorry, should have added that. About 1 or 2 mm's is enough.
Old Jan 26, 2010 | 05:18 PM
TorqueTerrorist
Audi 2.0T FSI
Thanks mate
Old Jan 26, 2010 | 05:20 PM
TorqueTerrorist
Audi 2.0T FSI
Thanks guys.
Yea i know SCC but the car is in Derby. Does anyone know of a specialist near or around Burton?
Vincereese
Jun 1, 2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
3i Jim
Nov 20, 2015 05:12 AM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
