HPI check on a car with private plate?
Old Jan 18, 2010 | 12:09 AM
wirralphil's Avatar
wirralphil
Default HPI check on a car with private plate?
Would this be ok or do i need the original plate?
Also where is the best place to get a HPI check from?
Thanks Phil
Old Jan 18, 2010 | 12:12 AM
MarkyMark's Avatar
MarkyMark
just do it on the private plate it will come up
Old Jan 18, 2010 | 07:59 AM
matts1's Avatar
matts1
Off the private plate will be fine, it will/should tell you there has been a plate change.
Personally I would do the hpi from hpi about £20 as these cheap text checks don't seem to be 100%
j.hammond1
30
Oct 31, 2021 05:28 PM
kosienutter
31
Aug 22, 2015 09:55 AM
fuzzy
Aug 9, 2015 09:43 AM
creator
Aug 2, 2015 12:24 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
