metal clutch quadrant
Hi, i need a metal clutch quadrant for my escort mk6 van, from where can i get one pls? The pressure plate is a Helix one, the original plastic quadrant broke two times already on it. Any help pls? Thanks, justin. Pls email me on justin.grech@gov.mt
[quote=JUS018;5016336]Hi, i need a metal clutch quadrant for my escort mk6 van, from where can i get one pls? The pressure plate is a Helix one, the original plastic quadrant broke two times already on it. Any help pls? Thanks, justin. Pls email me on justin.grech@gov.mt
[quote=JUS018;5016338]
http://www.extremesportsproducts.com...d&productId=17
it says they are out of stock
ill find out tommorow
120 pound ???so expensive
well I built my ib5 gearbox with rst lsd and flat relase bearing in and with ap 2000-8 organic clutch
i started to built in the white quarand 10 teeth cut and the mk5 pedal
but i don t like it to mutch play a stretching when pushing the pedal
with the ap 2000-8 maybe the standard mk4 pedal can be use
well I tried with the original mk4 quadrant with automatic adjust and the pedal is very hard an the clutch way is to short when im holding the pedal on the floor an let it 1mm up is directly clutching the way is to short and the 1 gear don t go in very well
well I try with the mk5 quadrant like the ap racing clutch sayed
but need to drill a hole to take the spring an hold the pedal down
Drill the pedal and weld a nut to it. Then use a head bolt with another nut on it to lock it in the correct place. Replicated mk5 without the need to remove the pedal.
if its broken then obviously no choice but to remove it.
In all the years I have been building, racing cars I have mot needed a metal jazzy quadrant.
well I already have a mk5 pedal
but d on t know why but I d on t need to cut the quadrant 10 teeth off because with the cut off my bolt was on maximom to have clutch relase
maybe because the car is a left drive and the clutch cable to long
well I just bought a new mk5 quadrant big radius an try witouht cutting it off
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
