Vauxhall Vivaro, Renault, Nissan Vans
Old Jan 17, 2010 | 08:19 AM
LHD220Turbo's Avatar
LHD220Turbo
Default Vauxhall Vivaro, Renault, Nissan Vans
morning
Last week i changed a slave cylinder on a Vauxhall Vivaro van (same vans as the renault & Nissan)
now the problem, the bloke i done it for says that the gearbox is really notchy going from 1st to 5th, before the slave went he said he used to be able to change gear using one finger as it was so smooth
anyone come across this before? i'm pretty sure i routed the gear cables correctly
also, anyone got autodata to check the grade of oil for the box?
Old Jan 17, 2010 | 08:24 AM
LHD220Turbo
ps, its a 55 plate 6 speed
Old Jan 17, 2010 | 08:40 AM
c2ssv's Avatar
c2ssv
the best 4x4xfar
i did 2 ov these and both were a nightmare. and it ended up bein the slave on the pedal aswell as the 1 in the box but mine was a slightly different problem to yours it was in every gear. it was ok 4 a couple ov days then started playing up.
Old Jan 17, 2010 | 09:14 AM
dingla rs's Avatar
dingla rs
Originally Posted by LHD220Turbo
morning
COSTLY BILL MATE MINE WENTS LAST YER 1700QUID FOR REFURBED GEAR BOX AN NEW CLUTCH +SLAVE CYLINDERS ,ITS A FAULT ON THEM BEARINGS GO
Old Jan 17, 2010 | 09:16 AM
utternutter's Avatar
utternutter
whats is it with gearboxs on those vans, i look at the price of salvage ones they make fooking loads, so spose the engines are worth money too which means they also must go for a past time
Old Jan 17, 2010 | 09:21 AM
Bobs rst's Avatar
Bobs rst
if in doubt flat out
gear boxes are shit that why the bearings go bloke that did mine showed me bearings they use plastic compared to ones he put in ,wouldnt buy second hand one tho probly have same problem
Old Jan 17, 2010 | 09:27 AM
D16PJM's Avatar
D16PJM
i had one of these vans for 2 weeks and learnt my lesson, bought a 05 toyota hiace not quick but given me no trouble, the amount of these vans for sale with gearbox faults, surely vauxhall should of did a recall.
Pete
Old Jan 17, 2010 | 10:04 AM
john_p_b's Avatar
john_p_b
did the clip come out at all that adjusts the length of the gear cables? Had the same problem in the past and that was the cause.
Old Jan 17, 2010 | 10:07 AM
john_p_b's Avatar
john_p_b
as for the oil, they spec a 75/80 grade. Fitted more gearboxes to those vans than i care to remember!
Old Jan 17, 2010 | 10:26 AM
carfixz's Avatar
carfixz
Pete
on a van buily by renault, terrible vans, worked at a vaux dealership and they caused major trouble, very unreliable
Old Jan 17, 2010 | 10:28 AM
steves24V's's Avatar
steves24V's
you havent filled the gearbox to the level of the fill bung have you, sounds the same as what i did made the gearbox very tight, dain it out and put in 2.6 ltrs of 75w/80w.
but as said above have also changed the clutch master cylinder and the gearboxs do shit them selfs quite often.
Old Jan 17, 2010 | 11:35 AM
lewismk1's Avatar
lewismk1
Ive done three clutches now and each time ive had to change the master cylinder on the pedal.
Just make sure if you do another to change it all, clutch, concentric and master cant go wrong then.
£24 for the master cylinder from vauxhall so no big deal.
Crap van imo, we have had atleast 4 in broken down with crank sensor wiring faults too.
Old Jan 17, 2010 | 11:43 AM
opposite lock's Avatar
opposite lock
whilst the discussion about these vans are here, anyone know why my pals one wont rev if the cluth is pressed in then revs freely when in neutral at idle. He cant pull away without 'slippin the clutch' but wil cruise like nothings wrong when it gets its speed up. Its very dangerous at pullin away , gearbox works fine !!!
Old Jan 17, 2010 | 02:46 PM
LHD220Turbo
think i sussed it mate, for some reason i had it in my mind that they were no adjustable - i adjusted one and it did seem better; hopefully the guy i done it for will think the same
as for the gearbox i put a 80 weight oil in and 2.6l so i think that was alright
cheers all for your replies, and yeah these vans are shite; people buy them because they are quite nice to drive
Old Jan 17, 2010 | 02:52 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
I picked up numerous vivaros with fucked gearboxes when i did recovery, they just lock up. mostly had to use skates to get then off the truck and in the dealer.. they seem to only last about 60 to 80 thousand mile
Old Jan 17, 2010 | 02:58 PM
snoopaloopa's Avatar
snoopaloopa
Dont know why but my old transit and my current expert both do it as well, wont rev over 3k with the clutch pushed in, wonder if its to save the clutch to much abuse (i.e. fit cheaper clucthes as standard)?
Old Jan 22, 2010 | 09:31 PM
opposite lock
did they struggle to pull away ? its a good point tho m8
Old Jan 22, 2010 | 09:35 PM
3dr's Avatar
3dr
very common fault on these sheds is as follows:
fuelling problems
air mass meter
fuel regulators
fuel pumps
crank sensor wiring
list is endless.
Old Jan 22, 2010 | 09:43 PM
James998's Avatar
James998
It's to stop people abusing the fuck out of them and fucking the DMF usually, a rev limit of 3000 rpm so people cant do 5000rpm launches.
Old Jan 22, 2010 | 09:47 PM
mechanic28's Avatar
mechanic28
they newer ones dont suffer from bearing problems anymore!does the pedal feel ok mate?
Old Jan 22, 2010 | 09:55 PM
we are getting some of these vans at work. I dont think i wanna work on them now.
Old Jan 22, 2010 | 10:39 PM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Do you know from what year/month on that was cured? I get offered loads of fleet cars at work and funnily enough all of them Vivaros/Trafics have broken gearboxes....
Old Jan 22, 2010 | 11:03 PM
Cozzie Bhoy's Avatar
Cozzie Bhoy
Work mate has a Nissan, Went looking for a door trim for the passenger door. Main dealer wanted €170!! Went to an opel (Vauxhall) dealer and got it for €29 !!! The dealer either fooked up or else go to vauxhall for all your parts!
Rod-Tarry
75
Oct 13, 2015 04:44 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
