Inlet manifold question
on the mfi inlet, the 2 little elbows that come off, what i was thinking was to plug these up, and move the take offs somewhere else.
has anyone done this, and will it affect the readings?
Depending on how many you need, I moved mine to where the cold-start injector used to be (when I went EFi). I made a little blanking plate, with a take off on it. Meant I could keep all my vac hoses hidden.
Cor, that was some years ago!!
Si B
Sep 12, 2015 06:49 AM
