Puma engine in mk1 focus??
Old Jan 6, 2010 | 11:01 PM
evans2822's Avatar
evans2822
Default Puma engine in mk1 focus??
Hello guys,
I have a good focus shell 3door with a well blown 1.4 ive removed that and have a chance of a tuned 1.7 puma complete but damaged as the 1.7 is only a few horses down as std on the 2.0 zetec i was thinking of using it.. is this worth doing?? I was wondering about the gearboxes is the puma cable operated or rod etc any thoughts much appreciated...
Ah yes the 1.7 is tuned to 150bhp is it worth the hassle???
Old Jan 8, 2010 | 08:51 AM
craigk47's Avatar
craigk47
1.7 Ka
Sounds like a lot of hassle to be honest. Guessing it's a racing puma spec engine if it's up to 150?? You'll need different engine mounts, the gearbox is different-ib5 as opposed to mtx75 i think (not sure how this differs with the cables/rods but might mean you need different driveshafts) pumas also run the variable cam timing and I'm assuming you'd have to run it on a racing puma ecu and loom. Could put any engine you want in for that much messing about. You can get an st170 lump for less than a grand and I'd imagine they just drop straight in.
Old Jan 8, 2010 | 01:31 PM
evans2822's Avatar
evans2822
Cheers for reply i was thinking it may be a pig of a job maybe stick with std focus parts instead then...
Old Jan 8, 2010 | 01:33 PM
craigk47's Avatar
craigk47
1.7 Ka
Be a lot easier pal. Only know myself because I've just bought a frs engine to go in my puma
craigk47's Avatar
craigk47
1.7 Ka
A lot more tuning potential in the zetec and duratec engines than the SEs
Old Jan 8, 2010 | 01:42 PM
OldDan's Avatar
OldDan
Zetec-SE's are very tunable.
Old Jan 8, 2010 | 01:49 PM
craigk47's Avatar
craigk47
1.7 Ka
Maybe so but only to a point and the parts aren't as readily available
Old Jan 8, 2010 | 01:59 PM
OldDan's Avatar
OldDan
What parts are hard to find?
Old Jan 8, 2010 | 03:50 PM
RichieST's Avatar
RichieST
Should fit ok. They put the focus 1.4s in the pumas, so the 1.7 should fit without toooooo much bother!
Old Jan 8, 2010 | 03:54 PM
jammerrs's Avatar
jammerrs
its doable i reckon, se for se, cant be that hard!?..........famous last words haha
Old Jan 8, 2010 | 04:06 PM
evans2822's Avatar
evans2822
Thanks for the replys guys i can get the whole car for £400 as its been side swiped and then parked up in a dry garage for 3-4 yrs and lady just wants rid thats why i was tempted i think i'll pop over and take a closer look see what the crack is....
Cheers...
Old Jan 8, 2010 | 06:10 PM
craigk47's Avatar
craigk47
1.7 Ka
So is the focus 1.4 engine an SE or an E? Apologies if I've been talking crap.
Old Jan 8, 2010 | 06:40 PM
jammerrs's Avatar
jammerrs
SE mate, as is the 1.6 focus Mk1. the Mk5 fiestas all use Se's to as do pumas
E's are the 1.8 & 2l focus's and mondeos i beleive
thats why i reckon itll be easy to do, and if its only £400 if it all goes wrong itll break for more than that anyway
Old Jan 8, 2010 | 06:53 PM
OldDan's Avatar
OldDan
SE is the 1250,1400,1600,1700 engines in Fiesta/Pumas.
Old Jan 8, 2010 | 07:22 PM
MisiekT_PL's Avatar
MisiekT_PL
go for it, should be about the same amount of time/money as putting another 1.4
Old Jan 8, 2010 | 07:36 PM
Ginger Will's Avatar
Ginger Will
surely like for like?
Old Jan 9, 2010 | 02:59 PM
evans2822's Avatar
evans2822
Im going to give it a go i reckon...Ive kept the alternator/engine combi bracket mount and some other bits and bobs that should aid me..I going to see the car in the week I 'll let you all know how i get on!!
Old Jan 9, 2010 | 09:52 PM
fiestamk2's Avatar
fiestamk2
engine will drop straight in,you will need the engine bay loom,ecu maf,key,and what ever sensors are needed should be fairly straight forward really,go for it i say
Old Jan 10, 2010 | 12:54 AM
ScORTED's Avatar
ScORTED
Project Money Pit
wouldn't hurt the se is a great little engine out the box, just so so revvy even stock, was great fun in a fiesta dunno how rapid a focus would be with one in though as they're not very torquey
Old Jan 17, 2010 | 06:06 PM
smudger068's Avatar
smudger068
how you getting on fitting it?
Old Jan 18, 2010 | 10:34 AM
evans2822's Avatar
evans2822
I picked the car up and the damage hardly warranted the car being taken off the road so i flogged it to my brother he's using it now it goes well tho fairplay....Problem is i still have an empty space in the front of my focus lol...
Old Jan 20, 2010 | 08:57 AM
craigk47's Avatar
craigk47
1.7 Ka
I could sell you an frp engine. Wouldn't be as cheap as your last one though Plenty of cheap fiesta zs engines on fleabay. As I was talking shit when I said they weren't very tuneable you can get 210 brake out of them with throttle bodies, cams, management etc
Old Jan 20, 2010 | 08:59 AM
craigk47's Avatar
craigk47
1.7 Ka
still go for a 2.0 duratec / zetec myself though. Plenty of torque for the extra weight of the focus
Old Apr 13, 2013 | 07:25 PM
Aarong.20's Avatar
Aarong.20
Just done this conversion went very smoothly as the blocks are extremely similer, just need to modify drivers side mount as had to use the focus one also need to swap round power steering pump.
Old Apr 14, 2013 | 07:57 PM
smudger068's Avatar
smudger068
Excellent, What spec focus did you put in? What did you do with loom etc? any pics?
Thanks
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
