mk6 pedals in a s2???
Old Jan 2, 2010 | 09:41 AM
adam h's Avatar
adam h
Default mk6 pedals in a s2???
my clutch seems really low to the floor, when i rasie my foot off of it it clicks, if i have my foot on the brake pedal the sometimes the clutch wont engage properly,
is this cos my pedals are loose, someone mentioned to me about putting mk6 pedals in instead of the standard?? is this simple to do or do i have to modify them in any way?? has anyone done this??
cheers
Old Jan 2, 2010 | 09:45 AM
bad boy rs's Avatar
bad boy rs
i did this in my s2 when i fitted a ap paddle clutch, its a simple but affective mod, you need the mk6 peddle, quadrant although i think you can get metal ones now and the rubber for the peddle. Very tricky to fit though if i remember
Old Jan 2, 2010 | 11:28 AM
Karlos G's Avatar
Karlos G
Balls Deep!
You just need a new quadrant, the clicking sound you here is beacause it's plastic and the teeth chew or brake off and so is slipping a few teeth.
They are about £5 new, but awkward to fit! lol
Mk6 pedal can be fitted but no need unless your running a AP Racing clutch.
Old Jan 2, 2010 | 11:54 AM
crazycage's Avatar
crazycage
i would do hydraulic conversion on it nice and easy and can be done and a few hours if you where to buy the right bits .
Old Jan 2, 2010 | 11:57 AM
KSA-Cossie's Avatar
KSA-Cossie
I just changed the clutch pedal on my s2 when i fitted an ap clutch
Old Jan 2, 2010 | 05:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Still waiting to finish and try mine out...... maybe sometime this decade!!
Old Jan 2, 2010 | 05:07 PM
Matthew_M's Avatar
Matthew_M
any info on where to get the bits and whats needed?
Old Jan 2, 2010 | 07:21 PM
adam h's Avatar
adam h
cheers for the replies, i'm gonna be after a new clutch over the next few months so might go down the ap route, and will look into the quadrant.
Old Aug 2, 2010 | 04:50 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
how does the manual adjust pedal differ from the standard gear?
I dont fancy the quadrant going cause its a pain in the arse to change especially if its only been done recently.
wont be doing mega miles so i would prefer to be able to adjust it every other month and know for sure that its going to be solid forever.
Old Aug 2, 2010 | 04:53 PM
AstoN_B's Avatar
AstoN_B
am i right in thinking it still uses the same design but instead of being spring loaded there is a bolt to adjust the quadrant?
in my experience its the pawl bit that ruins the teeth on the quadrant, are there any options which do away with this design?
mk1turboestate
Dec 2, 2015 08:31 PM
massivewangers
30
Oct 1, 2015 07:40 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
