S2 Rev Counter
Old Jan 2, 2005 | 08:33 PM
ColinRS's Avatar
ColinRS
Default S2 Rev Counter
I just got a new set of clocks for my s2, but when i tested them i noticed that my rev counter is ticking over at 2k revs and when i give her throttle the rev needle flies away around onto the speedo, way past the original red line, any ideas??
Old Jan 3, 2005 | 12:40 AM
white cab's Avatar
white cab
you have got a set of efi clocks not the mfi ones
Old Jan 3, 2005 | 12:54 PM
ColinRS's Avatar
ColinRS
aint got a clue, i think they came out of an escort Cabrio
Old Jan 3, 2005 | 12:59 PM
white cab's Avatar
white cab
the efi clocks run a coil pack so the signals sent to the rev couter are twice as fast as the ones sent by the mfi coil so that is why your reading is 2k at tick over change the clocks to solve the problem
Old Jan 4, 2005 | 06:56 PM
mkv_turbo's Avatar
mkv_turbo
is there any way of sorting the prob?
i get the same thing in my mk5 escort
Old Jan 4, 2005 | 08:48 PM
white cab's Avatar
white cab
what engine is the mk 5 efi has it been modifiyed from standard.
Old Jan 4, 2005 | 09:28 PM
sufsRS's Avatar
sufsRS
another quest got same prob wiv mine it goes up the clock alot faster than usual but the idling speed is at 1050 which is correct is this stil the same prob as above????
Old Jan 4, 2005 | 10:16 PM
white cab's Avatar
white cab
check wires to the coil.
if all is ok change the speedo you can pick them up cheap enough any way.
why is it idleing at 1050 what car is it if it has an idle valve that is on its way out
Old Jan 5, 2005 | 10:22 AM
sufsRS's Avatar
sufsRS
its a s2 dot they all idle their??? both of mine idle their, i switched the clocks round from my other turbo which are workin fine and exactly the same happens!!!!!
Old Jan 6, 2005 | 01:27 PM
mkv_turbo's Avatar
mkv_turbo
its got a S2 erst engine in it
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
