mfi metering head help
Old Dec 29, 2009 | 05:57 PM
jim393's Avatar
jim393
Default mfi metering head help
ju st replaced engine in rs turbo that had blown up.I brought it not running and
abandon it in a lock up for just over a year. i have the new engine all fitted but
it fires some times but won,t stay running.I have got good fuel pressure to the
metering head and the cold start injector but nothing to 4 injectors.It will run if i
give a sniff of easy start so diffanately fuel. any one have any ideas?
thanks jim
Old Dec 29, 2009 | 06:04 PM
Rob_DOHC's Avatar
Rob_DOHC
Sounds silly but does the metering head flap move easily? if it has been standing for a long time this may have seized/stiffened up etc. The flap position correlates to how much fuel is injected.
Take an injector out next and look at what it does when the engine is cranked (unplug the cold start injector to avoid totally fludding whilst you are playing about), and when you push on the flap.
Let us know what happens
Rob,
Old Dec 29, 2009 | 06:05 PM
Rob_DOHC's Avatar
Rob_DOHC
Forgot to say that if fuel does not come out of the injector, and the flap moves with ease it if possible that your fuel distribution head (the but on top with the injector pipes coming out) could be in trouble....
Rob,
Old Dec 29, 2009 | 06:23 PM
jim393's Avatar
jim393
Thanks for your reply
The metering flap moves freely if i push the flap
down whilst the engine is cranked it still does't
deliever any fuel out of the injectors
Old Dec 29, 2009 | 06:34 PM
Rob_DOHC's Avatar
Rob_DOHC
and comes back up easily? I would suspect the distribution head tbh, but it could be a couple of other things.
Not sure of any one who rebuilds these..... might be easier to locate a known good one.
Rob,
Old Dec 29, 2009 | 07:11 PM
orionmojo's Avatar
orionmojo
Rob,
Norris Motorsport rebuilt my metering unit, but my Orion turbo was in there having a f***ing fortune spent on it at the time
Old Dec 29, 2009 | 07:37 PM
morph's Avatar
morph
defo sounds like dodgy meter head, easier to buy another one mate, i know someone who has one that is working 100%.
Old Dec 30, 2009 | 05:51 AM
cris4rst's Avatar
cris4rst
Need MOT
I had similar problem, it would fire up on cold start injector but wouldn't run,
No fuel from the 4 injectors, but there was lots of pressure and fuel would spew from the head if the bango bolts were slackened,
Turned out the Pump was drawing air caused by low fuel level, - make sure u got at least 2 jerry cans in the tank -
sometimes it's the simple things,
good luck
chris
Old Dec 30, 2009 | 05:26 PM
jim393's Avatar
jim393
Talking it runs
Thanks for that chris.As i had plenty of pressure but nothing out
of the banjos didn't think it would be that.But as its a van unknown to me
i put 25ltrs of fuel and it runs. cheers jim
Old Dec 30, 2009 | 10:01 PM
Rob_DOHC's Avatar
Rob_DOHC
lolololol thats very funny. Glad it works mate.
Rob,
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
gingeRS
17
Oct 2, 2015 09:42 AM
DAZZER
Sep 30, 2015 08:43 PM
