General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I know alot of people use rover turbo inlet manifolds on zetec turbo builds, who do you get your adaptor plate from, or can you get the flange cut off, then for example an EFI flange welded on? Are the port sizes/shapes similar? Also, what throttlebody do people use?
mine had an ally plate welded to the rover mating face but a mate of mine has an adapter plate from friday (spelling as allways) engirnearing the ports match very well
you can use the standard throttle body but i had a cossy one fitted
