mt 75 gearbox
Old Dec 13, 2009 | 07:01 PM
charliecosworth's Avatar
charliecosworth
MG Maestro turbo 437
Default mt 75 gearbox
my cosworth has very small whine in 4th and 5 th gear i have decided to change gearbox there a few on ebay, just simple question all they all the same? all 4x4 gearboxes.
this is the one i bought for only £52!! but is it the correct one?
Peter
Old Dec 13, 2009 | 07:44 PM
2ndGear's Avatar
2ndGear
no they are not all the same, they look it but they are not. The clutch piviot pin is different in a DOHC, the ratios are different and the output shaft might be different there are two types.
Old Dec 13, 2009 | 08:09 PM
zetecturbo's Avatar
zetecturbo
itl fit mate,just change the pivot pin and fork from ur old box over and the gearstick cradle and then use the 3 long threaded bolts from ur own rear output flange and il be find ,ratios will be differeny but shudnt be enough to cause harm
Old Dec 13, 2009 | 08:39 PM
charliecosworth
cheers mate...may be i take mine off and try getting one from escort cosworth.
Old Dec 13, 2009 | 09:08 PM
Dave Hewy's Avatar
Dave Hewy
ive been wondering this as i want a big tooth gearkit, maybe an oppliger but i would rather get a cheap box and get it built up, then i can do a straight swap.
Old Dec 14, 2009 | 05:39 AM
grcossie's Avatar
grcossie
Yust get a box whit broken 3gear, you get them for cheap.
Old Dec 14, 2009 | 07:01 AM
Rich_bloor's Avatar
Rich_bloor
rich_bloor@hotmail.com
have you tried changing the oil in your gearbox and making sure its at the right level? low oil can make them whine in high gears.
Old Dec 15, 2009 | 03:47 PM
dojj's Avatar
dojj
Resident Wrestling Legend
ratio's are the same in the boxes
Old Dec 15, 2009 | 05:47 PM
charliecosworth
so i can fit the gearbox i already bought?
how hard is it to change the pivot pin and fork which i been told is diffrent
Peter
Old Jan 5, 2010 | 04:44 PM
Oppliger Motorsport's Avatar
Oppliger Motorsport
Romain
Default oppliger ENGINE & GEARBOX....
first road test of our powerful Cosworth car....1.6 bar of boost....we have to finish the map for 2.2bar...
engine spec:Nikasil liners on 200 block,10 long studs,Arrow cranckshafts,Arrow rods,forged pistons,ported head,double valve springs,Nimonic valves,solid followers,wild camshafts,wrc 8 injectors manifold,swedish plenum,70mm body,tubolar exhaust manifold,gt35 turbo,external wastegate,coil pack,pectel super 8,twin 044 fuel pumps,etc....ops....Oppliger BIG TOOTH GEARKIT
videos:
http://www.youtube.com/watch?v=wlwjhSHrJiA&feature=response_watch
http://www.youtube.com/watch?v=HZwbfVGnaw4&feature=response_watch
Old Jan 6, 2010 | 05:38 PM
Dave Hewy's Avatar
Dave Hewy
Sounds very nice.
Old Jan 6, 2010 | 05:52 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
who give's a fuck about a whine................unless it goes BANG.......so what.....
Old Jan 6, 2010 | 09:30 PM
Paul_RS's Avatar
Paul_RS
The rear output flange can differ too. There are two types, one takes the early thick rubber donut, the other takes the thin later type donut. You need the matching donut and front section of the rear prop for everything to match up nicely
Old Jan 10, 2010 | 11:34 AM
2ndGear's Avatar
2ndGear
are they fuck the same. the cossy is geared for 3.62 diffs has a 25 tooth input shaft the DOHC is geared for 3.9 diffs and has a 26 tooth input shaft. If you had two cars side by side you can tell the difference especially on boost.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
gingeRS
Sep 4, 2015 06:29 PM
