Turbo Civic
Old Dec 11, 2009 | 11:22 PM
RickyLee53's Avatar
RickyLee53
Default Turbo Civic
Heres how it was a couple of months ago.
Manifold I finished earlier this week.
Not a lot left to do now,
Old Dec 11, 2009 | 11:27 PM
Munch's Avatar
Munch
Mr. Sparkle!
thats gonna be an animal!
Old Dec 11, 2009 | 11:34 PM
andy130's Avatar
andy130
fuck me thats mad manifold looks mint
Old Dec 11, 2009 | 11:35 PM
stembo21's Avatar
stembo21
i like that wot have you done about lowering the compression
Old Dec 12, 2009 | 12:00 AM
rst in breaking's Avatar
rst in breaking
never have i seen a turbo soo easy to plum into cooler, bet that took some working out lol, cool project
Old Dec 12, 2009 | 12:42 AM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
hop the engine dont rock to much lol
Old Dec 12, 2009 | 07:27 AM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Looks good, guessing it's just for strate line / strips? as turbo seems in prime spot for shit to go in it.
Old Dec 12, 2009 | 09:30 AM
RickyLee53's Avatar
RickyLee53
Nothing as of yet, I'll run about 17psi on the standard engine, this should give me 400bhp. I'm waiting for the parts to come from the states to build my other engine. But the stock 1 will be plenty for the winter.
That was the idea, the exhaust is just as simple, 1 90 degree bend and a silencer.
Haha, ye the mounts are nearly solid.
It will be road legal, obviously aimed at strips etc, A filter will be fitted for road/track use though. I had the last turbo there and it was ok, even when caught in the rain. Free water injection
Old Dec 12, 2009 | 05:49 PM
fatmike's Avatar
fatmike
y have u got 2 wastegats ? surly that will play up with the exhaust flow ?
Old Dec 12, 2009 | 06:10 PM
stembo21's Avatar
stembo21
how much has it cost you to do? think am getting a civic lol what management you useing
Old Dec 12, 2009 | 08:09 PM
sbd16v's Avatar
sbd16v
i expect he is using a twin scroll turbo so needs to vent both sides
Old Dec 12, 2009 | 08:33 PM
fatmike's Avatar
fatmike
but in a 4 in to 1 style manifold if u fit the wastegate at the collector surley that will be ok?
Old Dec 12, 2009 | 08:43 PM
lead_foot's Avatar
lead_foot
is awesome
It's not a 4 to 1, its a twin scroll.
Old Dec 12, 2009 | 08:56 PM
fatmike's Avatar
fatmike
neva hurd of one of them befor
Old Dec 12, 2009 | 09:00 PM
sbd16v's Avatar
sbd16v
they have 2 different size exhuast wheels in the same turbo
Old Dec 13, 2009 | 07:25 PM
RickyLee53's Avatar
RickyLee53
As above it's twin scroll so needs 2 gates.
Tried to map it today but it's faar too wet, spins 5th.
Old Dec 27, 2009 | 08:38 PM
timrud's Avatar
timrud
Any updates?
Old Dec 27, 2009 | 08:47 PM
RickyLee53's Avatar
RickyLee53
Originally Posted by timrud
Any updates?
Not really, weathers been shocking (as you know).
I've never actually managed to get it grip for a full gear. I've got some 225 wide R888s i'm sure in the dry it will put the power down ok with them on.
Running 1.3 bar of boost its very quick. I'd predict high 400's. (still can't believe how well it spools)
I've ordered, sleeves, pistons, rods etc from the states, so will be 4-5 weeks till any more major updates.
Also ordered lots of T45 so we can add some safety but more importantly loose some more weight
Old Dec 27, 2009 | 08:51 PM
RickyLee53's Avatar
RickyLee53
Couple more pic's here.
Temp filter while the new 1 comes.
Old Dec 27, 2009 | 09:04 PM
melspec1's Avatar
melspec1
I dont know if you thought about supporting the turbo wait! as if you got very stiff ride suspension any lumps or bumps will effect the engine to move about? ''not much but hash bumps will move the motor! so with the turbo unit so fare out you need to put on some sort of damper on it, other wise you start pulling the studs from your cyl-head!
you mite think this will not happen, beleave me it DUZZ...
Old Dec 27, 2009 | 09:22 PM
RickyLee53's Avatar
RickyLee53
The engine mounts are pretty solid, the cooler is mounted solid to the body, and the exhaust is mounted to an engine mount.
Theres not a lot of flex, and the thermal expansion of the manifold plays havoc with braces. I did look at some kind of rose joint affair and still haven't ruled it out completely.
We ran the original setup very similar to this (but smaller turbo) for some time and never had a problem.
Thanks for you concern though
Old Dec 27, 2009 | 09:24 PM
rstdave's Avatar
rstdave
Looks awesome mate, very well thought out!! Is it still a 1.6 then?? What's the engine spec if you don't mind me asking?
Dave
Old Dec 27, 2009 | 09:58 PM
RickyLee53's Avatar
RickyLee53
Dave
1.8 now, 100% stock engine done 100k miles in another car.
Building a nice engine for the 2010 season.
Old Dec 28, 2009 | 08:21 PM
stembo21's Avatar
stembo21
what management are you using?
Old Dec 29, 2009 | 09:48 AM
B1G_RST's Avatar
B1G_RST
i cant beleve this is runing still, me and my mate turbod his b16a2 jordan with out low comp pistons running 6-7spi and its blew the hg,
so that a b18 bottom end now ?
Old Dec 29, 2009 | 10:03 AM
darrenb16two's Avatar
darrenb16two
I work for honda and if i had a pound for everytime we had someone come in to show us there turbo'd or supercharged civic and then come back in two weeks to show us how many pieces the engine blew into i would be a very rich man.
Hope yours goes well though mate, looks a crisp project. Good luck
Old Dec 29, 2009 | 12:24 PM
RickyLee53's Avatar
RickyLee53
We turbo'd over 20 last year without a single failure.
I think 1 or 2 are members on here.
Sounds like there not getting them tuned correctly. (send them my way in future and they'll last a LOT longer)
We've got 4 cars running over 400bhp on bone stock engines. The other 15 or so are running 300 and another couple over 350.
Old Dec 29, 2009 | 12:26 PM
RickyLee53's Avatar
RickyLee53
Sounds like you had some DET also, what managment did you use? You was probably lucky the head gasket went, I'm guessing it wasn't genuine or you reused old bolts and it lifted the head.
Hondata on this car, I sometimes use chrome if the customer wants to do it cheaper though.
Old Dec 29, 2009 | 03:27 PM
stembo21's Avatar
stembo21
so how much do you do the convestion for wot car do i need sounds good power
Old Dec 29, 2009 | 03:35 PM
marky_g's Avatar
marky_g
Fleet Manager
thats abit crazy why have the turbo there tho?
Old Dec 29, 2009 | 08:42 PM
RickyLee53's Avatar
RickyLee53
Any B or D series Honda really, ideally a B16, B18, or D16Z6. The B18, found in the EK VTi-s civic's and aerodecks take best to turbo'ing IMO.
A typical conversion for a drive in drive out build is Ł2500-3000, 300-350hp depending on spec and turbo etc. If you take care 400+ has proven to be fine. But we only pushed regular customers cars this far.
A few reasons, shortest boost pipes possible. Shortest exhaust, equal length twin screamer pipes, best cold air feed possible and because we make "normal" car's day in day out, so its nice to do something a little bit different.
If the admin/mod's want me to remove the prices etc above please let me know. I'm not looking to trade on here just post something a little different
Old Dec 29, 2009 | 09:46 PM
stembo21's Avatar
stembo21
any videos of it on the go
Old Dec 29, 2009 | 10:51 PM
RickyLee53's Avatar
RickyLee53
I haven't got any recent vid's (got a google phone that doesn't take them)
Heres a vid of an intergra we did, this was running 14psi and did a 12.2 on the day although this run was a 12.7 I think.
http://www.youtube.com/watch?v=BQlZ4JxwesQ
1 from years ago...
http://www.youtube.com/watch?v=DALWKTltrmw
I'll get some vids, i've just stripped it again to make some new parts new subframe, and a cage, (when it wheelspins in 5th at 100mph+ I think you need 1 )
Old Dec 30, 2009 | 10:47 AM
nigel b's Avatar
nigel b
ever thought about using the k series motor?
Old Dec 30, 2009 | 11:05 AM
stembo21's Avatar
stembo21
i like the civic and thats just 1.6?
Old Dec 30, 2009 | 11:28 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
thats awesome mate - fair play to ya!
Old Jan 1, 2010 | 06:08 PM
RickyLee53's Avatar
RickyLee53
Yes, Its not really worth the hassle, the engines are a bit tall, mounts and driveshafts don't aline 100% soon as you go big power if the shafts aren't perfectly straight your always going to have problems.
The k20 heads are better, but the B series heads flow plenty anyway.
Its not a 1.8, it was a 1.6 before.
Thanks,
Old Jan 1, 2010 | 10:35 PM
andy escos's Avatar
andy escos
awsome bet it sounds mad on full boost
Old Jan 1, 2010 | 10:38 PM
lead_foot's Avatar
lead_foot
is awesome
How about the H series engine, extra capacity?
Old Jan 4, 2010 | 11:56 PM
RickyLee53's Avatar
RickyLee53
Gearboxes are better on the B series, the engines lighter, fits straight in, which is a big bonus as shaft angles on the H are never optimum. Things like this are important when you want more power.
The H series make less power per litre, while been slightly bigger capacity they don't really make any more power, just torque a wider lower powerband, which isn't really need on a fwd.
