newbee advice
Old Dec 10, 2009 | 05:00 PM
matt24680's Avatar
matt24680
Smile newbee advice
hi there im new to the forum and im currenty driving a ford focus 1.8 zetec and was wandering could someone advise me a good induction kit that makes a nice sound is k and n the way to go??
Old Dec 10, 2009 | 06:17 PM
airzfocus's Avatar
airzfocus
alrite m8 i would stick a KnN panel filter in a st170 airbox with the st170 snorkel, you can remove the resinator box for more sound! aftermarket cone filters tend to just suck in heat from the engine bay.
Old Dec 10, 2009 | 07:05 PM
MisiekT_PL's Avatar
MisiekT_PL
BMC CDA if you have $$$
Old Dec 10, 2009 | 07:45 PM
matt1.8z's Avatar
matt1.8z
iv got a bmc cda did av a 170 setup with k&n filter no differance between them performance wise i can tell the bmc gives abit more induction noise
matt
Old Dec 10, 2009 | 07:58 PM
MisiekT_PL's Avatar
MisiekT_PL
yyp, no real performance gains, but the sound of CDA is great
Old Dec 10, 2009 | 08:03 PM
matt1.8z's Avatar
matt1.8z
yea is if u dont hav a intake hose fitted if u do it quietens it down alot
matt
Old Dec 10, 2009 | 08:55 PM
matt24680's Avatar
matt24680
hi thanx for all the replys the cda filter is quite expensive i found this one which is usually Ł172 but looks like a bargain wat do you guys think??does ny 1 have one??
http://cgi.ebay.co.uk/K-N-57i-INDUCT...item4cec7c7190
Old Dec 10, 2009 | 09:19 PM
thebigmacmoomin's Avatar
thebigmacmoomin
Exactly what I had on my 1.8, plus a 2.0l auto air deflector.
Old Dec 10, 2009 | 10:04 PM
MisiekT_PL's Avatar
MisiekT_PL
same here, wouldn't recommend if I didn't, though i have the intake going down behind the bumper, not the factory in the grille
you can hear it a bit here: http://www.youtube.com/watch?v=V4xhLSROC7w
Old Dec 11, 2009 | 04:31 PM
airzfocus's Avatar
airzfocus
yeah forgot the deflector tho i dont have one one mine yet dos it make a difference?
Old Dec 11, 2009 | 04:55 PM
thebigmacmoomin
Probally not a lot, but for only Ł8 or so from Ford, its not expensive.
Old Dec 11, 2009 | 09:21 PM
matt24680's Avatar
matt24680
hi is the k and n filter the way to go or is there a better option for under Ł100??
Old Dec 12, 2009 | 09:39 AM
thebigmacmoomin
You should be able to get the k&n panel filter, 2.0l auto air deflector, st170 airbox & st170 snorkel for about Ł100.
Old Dec 12, 2009 | 10:16 AM
matt24680's Avatar
matt24680
hi thanks for the reply if you could find one of these then i would be very greatfull iv been looking but havnt found ny yet.
Old Dec 13, 2009 | 09:31 AM
airzfocus's Avatar
airzfocus
ive had a few other filters on mine and it just makes the car stall when the engine bay is hot, KnN panel filter best for me!
Old Dec 13, 2009 | 11:44 AM
phil_focus's Avatar
phil_focus
i've got a 2l zetec and all i've dont is fit a K&N panel filter and ditched the old snorkel for a bit of cold air feed ductin going down to the lower grill. you have o take the airbox out and chop the little fins off the intake nozel tho to get it to fit on and i can remember the exact size either but its nice and cheap and does the job very well!
Old Dec 13, 2009 | 01:48 PM
matt24680's Avatar
matt24680
hi that does sound like a good option what is the sound like ??so take the snorkel out and replace it with cold air feed and a k and n panel filter .does the snorkel not act as a cold air feed or does that do something else?
Old Dec 13, 2009 | 02:11 PM
phil_focus's Avatar
phil_focus
its not realy any louder than standard but it flows more cool air so you get better power and throttle response.
the snorkel is a cold air feed but theres 2 down sides to it:
1) it gets air from only a narrow slit between the bonnet and deflector plate.
2) once you pull it apart you realise its very restrictive!
i might take the resonator box off the side for more roar but i doubt i'll be able to hear it as my exhaust is so loud...95db when held at 5k
Old Dec 13, 2009 | 02:35 PM
matt24680's Avatar
matt24680
hi every 1 sorry for all the questions but what about a k and n apollo kit any one have one??
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
