2.0 focus fueling problem??????????
Old Dec 6, 2009 | 09:55 AM
rsbenj1's Avatar
rsbenj1
Default 2.0 focus fueling problem??????????
been having some sort of fault i think it a fuel problem.
every time i go round bends or roundabouts at speed the engine dies and losers power. then when your back on the strait put your foot down starts to die at top revs help please?????
Old Dec 6, 2009 | 02:17 PM
CoupeUK's Avatar
CoupeUK
My 52 ST170 will die if you throw it into a right hander with less than a qtr tank of fuel.....seems a common thing on the Focuses as I test drove another to check and it was the same. Must be the fuel pick up in the tank is on the right hand side of the tank so it cant pick up when cornering. It wouldnt solve the loss of power at high revs though....?
Old Dec 6, 2009 | 10:07 PM
MisiekT_PL's Avatar
MisiekT_PL
the same here, just fill up the tank
Old Dec 7, 2009 | 06:59 AM
alex_666's Avatar
alex_666
hmmm thats strange my 1.8 gets hammered around every round about and all the country lanes and never had a problem! and most of the time the fuel is low as the damn car drinks like a fish!!
alex
Old Dec 7, 2009 | 08:09 AM
DMR's Avatar
DMR
mine does this replaced everything so far apart from fuel pump guess thats next, how hard is it to replace?
Old Dec 7, 2009 | 08:23 AM
rsbenj1's Avatar
rsbenj1
well i goin to up rate the fuel pump next just to be sure but think you might be right about the low fuel not sure though
Old Dec 9, 2009 | 11:47 AM
DMR's Avatar
DMR
mine only does it when it's just under a quarter tank or just before the petrol light comes on then it gets worse and worse till i fill it up. Never did this when i first got it 6 months ago just randomly started happening. Bloody annoying esp if u have someone up ya arse and the car loses power lol
Old Dec 9, 2009 | 02:08 PM
pani_k's Avatar
pani_k
PassionFORD Member
Fuel filter. Most probably blocked. Change this then get back to us.
Old Dec 9, 2009 | 07:25 PM
DMR's Avatar
DMR
Already changed mine 3 weeks ago made no diffrence
Old Dec 9, 2009 | 07:29 PM
pani_k's Avatar
pani_k
PassionFORD Member
There's something wrong in your system then as when the tank is full or got more fuel if the problem doesn't arise then it means something is wrong in the system not necessarily the fuel pump.
Old Dec 9, 2009 | 07:36 PM
DMR's Avatar
DMR
any suggestions?
Old Dec 9, 2009 | 07:39 PM
pani_k's Avatar
pani_k
PassionFORD Member
Not off the top of my head mate, I'll dig up some old threads on the FFOC regarding this as this has cropped up before.
Old Dec 9, 2009 | 07:41 PM
DMR's Avatar
DMR
Appreciate that mate
Old Dec 10, 2009 | 08:16 PM
woolford's Avatar
woolford
good man pani k
Old Dec 11, 2009 | 04:42 PM
Escow-Van's Avatar
Escow-Van
I don't mean to sound funny, but its not traction control is it?
Maybe try with it turned off.
Old Dec 11, 2009 | 05:42 PM
DMR's Avatar
DMR
mines not got TC
Old Dec 12, 2009 | 11:35 AM
Escow-Van's Avatar
Escow-Van
Ah fair enough, worth a try
Old Dec 12, 2009 | 03:08 PM
rsbenj1's Avatar
rsbenj1
well i know its not the esp as mine wont drive unless you take it off and already replaced the fillter so goin to tyr the pump next
Old Dec 12, 2009 | 09:41 PM
phil_focus's Avatar
phil_focus
it could be a cracked fuel pump mate.
think this is what happened to my mates st170
Old Dec 12, 2009 | 11:20 PM
DMR's Avatar
DMR
hopefully weather dependant ill get it up on the ramps tomorrow have a good look under the car. although without looking in me haynes can i see the fuel pump from under the car? or is it tucked away behind the petrol tank?
Old Dec 12, 2009 | 11:31 PM
phil_focus's Avatar
phil_focus
i cant remember mate.
i think there encased in a plastic housing or something and this can crack and some how fooks it up. sorry i dont know the details
Old Dec 13, 2009 | 08:27 AM
rsbenj1's Avatar
rsbenj1
thats the filter int it an sure the pump is inside the tank
Old Dec 13, 2009 | 09:15 AM
DMR's Avatar
DMR
Can't see it being in the fuel tank!!!!
Old Dec 13, 2009 | 11:32 AM
phil_focus's Avatar
phil_focus
the fuel filter is just infront of the fuel tank a bit hidden.
my be the fuel pump module as on the other thread
Old Dec 13, 2009 | 01:21 PM
DMR's Avatar
DMR
i know where the filter is, wheres the pump?
Old Dec 13, 2009 | 02:01 PM
CoupeUK's Avatar
CoupeUK
From what I heard, the pumps in the top of the tank.....
Old Dec 13, 2009 | 02:07 PM
phil_focus's Avatar
phil_focus
sorry yes the pump is in the tank as far as i'm aware
Old Jan 25, 2010 | 11:03 AM
MisiekT_PL's Avatar
MisiekT_PL
accidentally I came across this problem at Focaljet:
Originally Posted by Focaljet"
Years ago I got a mailing for the fuel pump on my '01 ZX3. It said that Ford will replace the fuel pump free of charge for up to 10 years from purchase date, if you have the failure symptoms. The early pumps had problems and if bad the engine will stumble on hard right hand turns and hills when under 1/4 tank. It can just die as well. I have had the stumbling a few times but not if I keep it over 1/4 tank. I will get it done before my 10 year expiration. I do not know off hand what years this special service covers.
I'm trying to get info from Ford if they recognize this as a fault and will they replace the fuel pump - if you have any way to check for yourselves - do it - if several cars with the same problem will show up, maybe there's a chance for a free service
Old Jan 25, 2010 | 12:02 PM
st170jim's Avatar
st170jim
check out the thread about st170 fuel under accel i put a pic on it of my fuel pump filter and in line filter urs will look the same!
Old Jan 25, 2010 | 12:08 PM
MisiekT_PL's Avatar
MisiekT_PL
my fuel filter is almost new... I experience the problem only when fuel is below 1/4 and only on hard turns (on track), so actually it happens very rare... but if Ford would be willing to replace the pum after some paperwork - no problem
Old Jan 25, 2010 | 01:20 PM
rsbenj1's Avatar
rsbenj1
what sort of papper work? but mine just reached its 10yr bday so am sh*t out of luck lol
Old Jan 25, 2010 | 01:26 PM
MisiekT_PL's Avatar
MisiekT_PL
paperwork meaning some letters/emails to Ford or Ford Europe...
by the way - if they consider this a factory fault, I don't think the 10 years limit would apply
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
