vibration on pull off
in my brothers saph when ya pull off u get a bad vibration we thing its the gear box mount (possible?) they wouldnt be hard 2 change when the cars on a ramp would they?
thanks martin
thanks martin
hiya martin the problem sounds more like the clutch not the gearbox mount but check it anyway has your bro had a new clutch fitted lately or is it still the same he had with car?if its an old clutch its stands a chance he has broke a spring or two on the pressure plate this will give a vibration on take off hope this helps
Fudgey
Sep 17, 2015 01:06 PM
