xr3i efi fuel pump
Old Nov 21, 2009 | 10:30 AM
danny_boy699's Avatar
danny_boy699
chatter 4 life
Default xr3i efi fuel pump
does any 1 know the fuel pressure a efi pump gives out in bar not psi, was told it was 2.5 bar but not sure
Old Nov 21, 2009 | 10:41 AM
The pump if the same as cossie and xr4i, the 941 is capable of around 10 BAR, this is why it has a fuel pressure regulator, to control the pressure in the fuel rail, most fuel rails are between 3 and 3.5 bar.
Old Nov 21, 2009 | 11:52 PM
danny_boy699
chatter 4 life
efi though like the fiesta turbo pump
Old Nov 25, 2009 | 08:08 PM
danny_boy699
chatter 4 life
any idea
Old Jan 5, 2010 | 04:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if you don't know already, then 8BAR should be right, cossie ones are a bit more.
Old Jan 23, 2010 | 04:58 PM
danny_boy699
chatter 4 life
thanks sean, so it should run a zetec turbo
Old Jan 24, 2010 | 06:03 PM
If it is the standard bosch pump the lockout pressure is 11.5 BAR, HIGHER than that of a cossie pump which is still only 11.2 BAR for the 044(group a).
For your 0 280 254 910 pump is 3.25 Litres/min at 3 BAR.
The cossie one can be safely used even the 044 if wanted.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
dms04
Sep 11, 2015 01:57 PM
