Injectors
Old Nov 19, 2009 | 09:10 PM
DMR's Avatar
DMR
Default Injectors
ello all
I believe my injectors may be blocked so i email ford for a quote on 4 new injectors they came back with £81.40 plus vat each, not paying that so what is the best way to clean injectors?
Thanks in advance
Danny
Old Nov 20, 2009 | 06:52 AM
SteveB's Avatar
SteveB
They need to be professionally cleaned ultrasonically.
Old Nov 20, 2009 | 07:43 AM
DMR's Avatar
DMR
do u think it is advisable to buy reconditioned ones off ebay?
Old Nov 20, 2009 | 07:55 AM
DMR's Avatar
DMR
what about STP fuel injector cleaner? i tried this other week when i filled the tank full i put a bottle in didnt do much but to me thats to much petrol to STP fuel injector cleaner so what would happen if i ran the car down to a couple of gallons put a bottle of STP fuel injector cleaner in and drove it hard?
Old Nov 20, 2009 | 05:55 PM
focusv8's Avatar
focusv8
What makes you think they are blocked?
Old Nov 20, 2009 | 07:38 PM
DMR's Avatar
DMR
following my haynes manual for fault finding, the car splutters alot over 50 mph, will splutter & backfire if i put my foot down from stand still. lacks power and over heat for a few secs if i do a constant 80 mph
I have looked for air leaks which i found on PCV Pipe? changed that, i have changed the oil + filter, fuel filter, spark plugs, ht leads, exhaust (complete) plus the lamba sensor, coolant emptied and flushed,
The spark plug wells have been filling with water which i know believe to be the core plugs which i will hopefully change tomorrow depending on the weather.
I'm out of ideas and injectors is next on the list unless you guys have other options?
Oh and it's a 2001 ford focus estate 1.6 Zetec & the engine management warning light is not on
Old Nov 20, 2009 | 08:43 PM
crazycage's Avatar
crazycage
it doesn't sound like the injectors to me. sounds more like plugs and leads
Old Nov 20, 2009 | 09:03 PM
DMR's Avatar
DMR
well im on my second set of plugs and leads in 2 months but then the core plugs are leaking so possibly
Old Nov 20, 2009 | 09:41 PM
dns2491's Avatar
dns2491
What about coilpack? the zetec-se are common for eating them. Also make sure you only put a genuine one on, as the aftermarkets tend to spell melt down for the pistons.
Old Nov 20, 2009 | 09:45 PM
COLEYST200's Avatar
COLEYST200
coilpack to me mate just go down the tat yard £5/£10 job done
Old Nov 21, 2009 | 06:40 AM
DMR's Avatar
DMR
Cheers guys i will get another coil pack and if that work i owe u all a pint
Old Nov 21, 2009 | 07:57 AM
focusv8's Avatar
focusv8
You need to stop water getting around the plugs before you spend any money on any thing else.
That'll cause miss firing.
First option after that is coilpack.
Old Nov 21, 2009 | 10:22 AM
DMR's Avatar
DMR
i have new core plugs which i will put in when it's stopped raining that should stop the leak i hope nothing else it can be, but im certain it's not plugs or leads as it done it when i renewed them first and second time. cleaning and drying the area then new plugs and leads still spluttered
Old Nov 21, 2009 | 11:59 AM
S1's Avatar
S1
Fuel pump is a common failure on the FRS. Also there is a breather pipe at the back of the engine that fails which causes similar symptoms. Try asking on the RSOC as there's a lot more FRS owners on there.
http://bbs.rsownersclub.co.uk/showth...ight=fuel+pump
Old Nov 21, 2009 | 01:56 PM
DMR's Avatar
DMR
right i have changed the coil pack which i did at the salvage yard, caused all kinds of problems for the first mile, then relised i needed to reset ecu so pulled over on A147 and disconnected the battery for 15 mins, went on my way and it's shit loads better, still hesitates from a stand still if i need to give it a little, like pulling off from a roundabout but it seems to lose power whenever i take a right turn, mainly roundabouts, it pull till i start turning then if decreases in power then next to no power at all untill i strighten up then it just kicks in and im flying again seems odd but seems like lack of fuel so am guessing fuel pump? is there a way to test a fuel pump?
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
