The Joys Of Water
Old Nov 10, 2009 | 09:06 AM
DMR's Avatar
DMR
Default The Joys Of Water
This might have been mentioned before but i have looked and not found anything, i have read on other forums about this problem with no result so thought i would ask in here.
2001 1.6 Focus Estate zetec
Problem is i am getting water in my spark plug wells over the course of a week i am getting 5mm or more of water in spark plug well 1 & 2 none in 3 or 4. I have taken the plastic cover off to check the rubber seal which is fine and also gave it a good clean and checked all over, can't see where water is getting in. i know some people say it's the washer jets leaking back so i have run mine dry and ran it for a week also ran it when it's not raining and still get the water i can not find out where it is coming from and is playing silly buggers with my Plugs & HT Leads
Any help would be great
Many Thanks
Danny
Old Nov 10, 2009 | 10:32 AM
RichieST's Avatar
RichieST
Either rain water leaking through washer jet holes in bonnet or could be a leaking core plug leaking coolant into the well, quite common too. Is it using any coolant?
Old Nov 10, 2009 | 01:30 PM
DMR's Avatar
DMR
Thanks for the reply
It's defo not rain water wheres the core plug?
Old Nov 10, 2009 | 01:51 PM
RichieST's Avatar
RichieST
There's a core plug in the well somewhere, it a round plug that seals the cooling system, about an inch in diameter, they are just pressed into the head and its not uncommon for them to leak. Is it using coolant?
Old Nov 10, 2009 | 01:55 PM
DMR's Avatar
DMR
It's not using coolant that i can see but i might be wrong if it's a small amount each week. I took the plastic cover off at the weekend theres a round metal bolt looking thing inbetween plugs 1 and 2 with a hex shape in the middle, is this what you mean? if so do i replace it?
Old Nov 10, 2009 | 06:51 PM
RichieST's Avatar
RichieST
That could be it, although the only core plugs i have seen look like a metal disc with rounded edges that just press fit into the head.
http://images.google.co.uk/images?hl...-8&sa=N&tab=wi
Look here and you will see what i mean. They are reasonably straightforward to fit, but you need to get them perfectly square when refitting or they will just leak again!
Old Nov 10, 2009 | 06:57 PM
DMR's Avatar
DMR
Cheers for the info mate
RichieST's Avatar
RichieST
In fact I have just had a look into it for you, those hex key bolt things are the core plugs!
http://www.fiatforum.com/non-fiat/16...r-fill-up.html
Have a read through this.
Old Nov 10, 2009 | 07:11 PM
DMR's Avatar
DMR
yup they are what i was on about, ill pop the cover off again weekend and have another look, cant see it being anything else to be fair. Thanks again for the info
Old Nov 10, 2009 | 07:21 PM
RichieST's Avatar
RichieST
No prob, let us know how you get on
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
