Cossie headgasket identification
Old Dec 28, 2004 | 11:03 PM
richm's Avatar
richm
Default Cossie headgasket identification
Sorry for the size of the pic, i wanted to maintain the detail as far as poss....
YB1261 gasket, is this a 'standard' sierra gasket, or a later Escort one - is it possible to tell from the picture?
Rich
Old Dec 28, 2004 | 11:32 PM
900ss's Avatar
900ss
RWD Racer
Yes, that is a gasket rich
Old Dec 29, 2004 | 02:41 PM
richm's Avatar
richm
erm... thanx Wyn...
anyone KNOW the answer please? is it an early or (supposedly better?) later one?
Rich
Old Dec 29, 2004 | 02:44 PM
Ian M's Avatar
Ian M
looks like standard sierra to me but not 100% sure.
Old Dec 29, 2004 | 04:24 PM
nomad's Avatar
nomad
the gaskets are the same for 2wd and 4wd , its a standard cosworth gasket you have there, if you require a group A one then the part number is YB0611. cheers nomad
Old Dec 29, 2004 | 04:56 PM
richm's Avatar
richm
cheers martyn, yeah definitely a "standard" gasket.. i was just wondering if it was the 'later' Escort version which i believe also carries the yb1261 reference, but is generally considered to be 'better'..? Maybe this just a myth and in fact all yb1261's are all the same.. ?
Old Dec 29, 2004 | 07:28 PM
Stu @ M Developments's Avatar
PassionFords Creator
Hi Rich,
I believe from recent purchases that the ST Esc Cos YB1261 has now superceded all YB gasket part numbers other than the YBo611.
Thats pretty much my understanding of things.
Old Dec 29, 2004 | 07:58 PM
wes's Avatar
wes
That gasket is exactley the same as a Grp A gasket, except it has 2 additional metal rings (which i have circled):
So it is infact slightly superior to the grp a gasket, and cheaper too Ford have to pay Cosworth a royalty to sell the YB0611 "grp A" gasket, thats the only reason they are more expensive than the YB1261.
Old Dec 29, 2004 | 08:05 PM
Alvyn's Avatar
Alvyn
sorry Wes,but that is a standard gasket and the reason they uprated from it without the metal rings round the water jackets was to stop the corrosion around that area of the gasket! none of the 4x4 gaskets that I've used have those rings
Old Dec 29, 2004 | 08:16 PM
All speculation IMO.
1) YB means Cosworth part number and NOT Ford. Therefore they must pay royalties on both or indeed buy from Cosworth
2) The rings are alloy and wouldnt corrode with water and anti freeze anyway.
Ive heard these stories so many times its untrue and from various sources. I believe the YB1261 is better for one reason and one reason only. Its the last gasket that FORD themselves fitted and i believe they would choose the best considering each would cost them the same.
Old Dec 29, 2004 | 08:23 PM
svony's Avatar
svony
I just recieved a YB1261 from Cosworth USA and it looks exactly the same as the one shown above. Should I be using this or get a Grp-A instead (4x4 engine)?, don't want to put the head on and find out this is not the correct gasket.
BTW. the gasket I removed was the same also but with the number YB1009/1 stamped on it.
wes's Avatar
wes
Old Dec 29, 2004 | 09:05 PM
richm's Avatar
richm
well, here's the one I've just pulled out this afternoon.....
i don't know how old this one is, minimum 6yrs old, but by the state of it, i'd have said it's been in there a while...
on a side note, what's the opinion of whether this eroded waterway would be why the cooling system was getting pressurised?
The firerings themselves all look good, no sign of an actual "blow", but under hard use, the cooling system was getting pressurised and lifting the pressure cap, hence the reason for the change.... The fibre part of the gasket is pretty crispy!!
Old Dec 29, 2004 | 09:11 PM
Alvyn's Avatar
Alvyn
I meant to say that the gasket gives/breaks away(in time) from those rings rather than corrodes as I know alloy DONT rust.
Old Dec 29, 2004 | 10:10 PM
abdr500's Avatar
abdr500
alloy dont rust at all
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
