fourbie saph turbo removal help urgent
Old Dec 28, 2004 | 11:58 AM
slowpoke's Avatar
slowpoke
Default fourbie saph turbo removal help urgent
ok the 2 front nuts i have got undone but the back 2 i cant get on
someone said if i remove the top alternator bracket i can get on the front nut is that right ?
how do i get on the rear nut tho at the back ? the exhaust downpipe is in the way
also how do i get the studs out of the back of the turbo that connect the exhaust to the turbo ?
any help greatly appreciated
matt
Old Dec 28, 2004 | 12:09 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
Old Dec 28, 2004 | 12:20 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Default Re: fourbie saph turbo removal help urgent
Old Dec 28, 2004 | 01:43 PM
tonyturbo's Avatar
tonyturbo
its a pure bitch of a job. done mine a whikle ago and at end of job i had all these modified, bent an twisted spanners to get into where the nuts are. good luck.
Old Dec 28, 2004 | 01:49 PM
Ginge !'s Avatar
Ginge !
just finding my feet
thats ment to be the easiest way
ask benn304r on here as he done a post about it along time ago and i belive he sorted it
Old Dec 28, 2004 | 01:56 PM
Eagle's Avatar
Eagle
Super Moderator
oh fook ... so i got this crap to come aswell then
Old Dec 28, 2004 | 04:02 PM
CosKev3's Avatar
CosKev3
Did'nt think of bending spanners when I did mine
Took exhaust manifold off nice job that too
Old Dec 28, 2004 | 04:20 PM
markk's Avatar
markk
i dont have any nuts on teh back two of mine !! , all i have to do is undo the down pipe unclick both oil pipes , remove one bolt and turn the turbo through 90 deg and its off !!
can swap blowers in approx 4mins taking my time !!
Old Dec 28, 2004 | 04:34 PM
Eagle's Avatar
Eagle
Super Moderator
4 mins bloody eck .. im on me way
does it not make any difference not havin the back 2 on then???
Old Dec 28, 2004 | 04:37 PM
DazC's Avatar
DazC
Might do if the car is used every day but Mark's is a competition car which is meant to break often!
Old Dec 28, 2004 | 04:40 PM
markk's Avatar
markk
did i miss out the bits like , the exhaust housings are quick release ? and that teh oil fittings just unclip like a compressor hose ??
as for the rear bolts , ive never had any problems what so ever , i do however lock wire the front two just for saftey
and my turbo is off after every event , so say every 100miles i take it off strip it , check and rebuild what it needs so i dont suffer from rusty seized bolts etc
markk's Avatar
markk
DazC,
Old Dec 28, 2004 | 04:42 PM
DazC's Avatar
DazC
Old Dec 28, 2004 | 04:46 PM
Eagle's Avatar
Eagle
Super Moderator
hhmmmmmmm
there must be a way..........
Old Dec 28, 2004 | 04:56 PM
DazC's Avatar
DazC
hhmmmmmmm
There is......Semtex! Bit messy though!
Old Dec 28, 2004 | 05:13 PM
Eagle's Avatar
Eagle
Super Moderator
hhmmmmmmm
imagine claiming on the insurance..
well my turbo blew up
DOO's Avatar
DOO
Just take the lot off manifold etc loads fooking easyer than pissing about trying to undo the turbo from mainfold trust me done it the other month
while apart fitted new gaskets and all the studs and nuts cost a mint but worth it
Old Dec 28, 2004 | 05:27 PM
DazC's Avatar
DazC
Have you thought about crow foot spanners and 'C' spanners etc for the extra versatility?
Old Dec 28, 2004 | 05:29 PM
slowpoke's Avatar
slowpoke
finally got my turbo off thanks for the help gus
now the fun starts trying to put the new one on tommorow lol
i WILL be asking for help again tommorow pmsl
p.s does anyone have any idea how much the 3 exhaust studs are from fords ?
cheers..............matt
Old Dec 28, 2004 | 05:36 PM
DOO's Avatar
DOO
about a £5 each
Old Dec 28, 2004 | 05:37 PM
Eagle's Avatar
Eagle
Super Moderator
anyone know the finis codes for the studs and nuts????
Old Dec 28, 2004 | 05:38 PM
slowpoke's Avatar
slowpoke
spose thats alright doo as i have to get them anyway
Rs Gus's Avatar
Rs Gus
told u matt done loads and never once FOOKED around taking manifold of far to much of a job 1hr should see turbo swapped withe THE CORRECT TOOLS!!!!!!!!!!!!
Old Dec 28, 2004 | 05:39 PM
Rs Gus's Avatar
Rs Gus
just get the studs from kwik fit ore somewhere alike
Old Dec 28, 2004 | 05:52 PM
DazC's Avatar
DazC
Correct tools? Does that include a 9" grinder, air chisel, 5 foot prybar and 6' scafold extension, assorted hammers and chisels, hacksaw, mole grips, stilsons etc etc?
Some Whitworth sockets just for good measure?
Old Dec 28, 2004 | 05:58 PM
Eagle's Avatar
Eagle
Super Moderator
best get the above tools then
Old Dec 28, 2004 | 05:59 PM
Rs Gus's Avatar
Rs Gus
so thats your special tool kit u keep talking about
Old Dec 28, 2004 | 06:03 PM
DazC's Avatar
DazC
Sorry Gus. I forgot you needed it back! I'll nip it into Stu's so you can collect it next time you're there!
Old Dec 28, 2004 | 06:12 PM
Rs Gus's Avatar
Rs Gus
Old Dec 28, 2004 | 06:13 PM
DazC's Avatar
DazC
Old Dec 28, 2004 | 06:16 PM
Rs Gus's Avatar
Rs Gus
Old Dec 28, 2004 | 06:38 PM
markk's Avatar
markk
it does for daz , he works with commercials , whats your excuse for having them gus ??
Old Dec 28, 2004 | 06:40 PM
extra17's Avatar
extra17
he's a PITBULL
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 29, 2015 08:16 PM
kevin36
Aug 14, 2015 08:36 AM
