fourbie saph turbo removal help urgent
ok the 2 front nuts i have got undone but the back 2 i cant get on
someone said if i remove the top alternator bracket i can get on the front nut is that right ?
how do i get on the rear nut tho at the back ? the exhaust downpipe is in the way
also how do i get the studs out of the back of the turbo that connect the exhaust to the turbo ?
any help greatly appreciated
matt
matt
its a pure bitch of a job. done mine a whikle ago and at end of job i had all these modified, bent an twisted spanners to get into where the nuts are. good luck.
just finding my feet
thats ment to be the easiest way
ask benn304r on here as he done a post about it along time ago and i belive he sorted it
Originally Posted by Eagle
4 mins bloody eck .. im on me way
does it not make any difference not havin the back 2 on then???
did i miss out the bits like , the exhaust housings are quick release ? and that teh oil fittings just unclip like a compressor hose ??
as for the rear bolts , ive never had any problems what so ever , i do however lock wire the front two just for saftey
and my turbo is off after every event , so say every 100miles i take it off strip it , check and rebuild what it needs so i dont suffer from rusty seized bolts etc
Just take the lot off manifold etc loads fooking easyer than pissing about trying to undo the turbo from mainfold trust me done it the other month
while apart fitted new gaskets and all the studs and nuts cost a mint but worth it
finally got my turbo off thanks for the help gus
now the fun starts trying to put the new one on tommorow lol
i WILL be asking for help again tommorow pmsl
p.s does anyone have any idea how much the 3 exhaust studs are from fords ?
cheers..............matt
Correct tools? Does that include a 9" grinder, air chisel, 5 foot prybar and 6' scafold extension, assorted hammers and chisels, hacksaw, mole grips, stilsons etc etc?
Some Whitworth sockets just for good measure?
impreza wrx sti version 8
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
