opening a bonnet on a 2001 transit with no key
Old Oct 18, 2009 | 06:03 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default opening a bonnet on a 2001 transit with no key
my lock is fooked to open my bonnet on my transit as you have to put them in the grill on this model.
how can i get the bonnet open?? even partialy drilled it with no luck
Old Oct 18, 2009 | 06:05 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
ive dun a focous at work with the same sort of set up as long as its cold you can pull the frount bit of the under tray off and get your arm up there i had to pull the rad down a bit as well
Old Oct 18, 2009 | 06:09 PM
Miller 3's Avatar
Miller 3
make sure the grill is not interfering with the key, you can just pull this off if it is in the way
Old Oct 18, 2009 | 06:20 PM
james kiely's Avatar
james kiely
i done mine mate ,you cant get your hand up [well i couldnt] so drilled it out then opened it with a screwdriver
cheers james
Old Oct 18, 2009 | 06:36 PM
Roosie's Avatar
Roosie
which way do you turn to get it open?
Old Oct 18, 2009 | 06:38 PM
Miller 3's Avatar
Miller 3
left to unlock (pop) then right to open
Old Oct 18, 2009 | 06:39 PM
godrikki's Avatar
godrikki
right till it pops up then left to fully open it
Old Oct 18, 2009 | 06:40 PM
Roosie's Avatar
Roosie
2 good answers
Old Oct 18, 2009 | 06:43 PM
james kiely
+1
Old Oct 18, 2009 | 06:49 PM
Miller 3's Avatar
Miller 3
Let me go and check, but im sure im right fpmsl
Old Oct 18, 2009 | 06:50 PM
n13los's Avatar
n13los
can you get it to pop? if so you should be able to get a ratchet spanner in there to undo the 2 bolts that hold the stricker to the bonnet.
Old Oct 18, 2009 | 06:58 PM
Miller 3's Avatar
Miller 3
yip i was right.. would be funny if i was wrong as i work for a hire firm and we have about 250/300 transits
Old Oct 18, 2009 | 07:21 PM
C4 opens them, or a blowtorch, failing that just tell some pikeys there's some copper under the bonnet!!
Old Oct 19, 2009 | 07:17 AM
Grantcos's Avatar
Grantcos
What type of key will open any lock........
A pi-key
Old Oct 19, 2009 | 08:18 AM
Roosie's Avatar
Roosie
cant even get it to pop cheers
Old Oct 19, 2009 | 08:57 PM
Miller 3's Avatar
Miller 3
In that case Stu you will probably have to try to unbolt the 8mm's on the latch and use some long nose pliers to twist it open! pop the grill out too mate.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
