RS2000 no spark
Old Oct 18, 2009 | 05:01 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Default RS2000 no spark
Hi there fellas i just wondered if anyone can help .... My RS2000 has just decided not to fire when i tried to start it ! The last time it started it was reluctant to fire but after about 15 secs it started , but now no spark ! I know that the coilpacks are a common fault on these but i didnt think they'd both give up at the same time ! Any ideas chaps ???
Old Oct 18, 2009 | 05:46 PM
Alvyn's Avatar
Alvyn
the rs2000 mk5/6 also suffer from bad fuse box loom issues!
Old Oct 18, 2009 | 05:47 PM
skinnybalboa's Avatar
skinnybalboa
joel b
hey would check over the condition of youre wiring going to the coil packs as this is very common for them to fail due to the heat under the bonnet, i would check that first, cheers
Old Oct 18, 2009 | 05:52 PM
Roscopeco's Avatar
Roscopeco
Ok mate thanks i, 'll test to see if theres power going to the coilpacks after work 2moro ! If theres power there , then id of thought there was a fault with them ! Or maybe they're ok and ive got a completely different fault altogether !
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
