Head gasket solution for genuine 650bhp
Old Oct 11, 2009 | 11:50 AM
sirmark's Avatar
sirmark
Default Head gasket solution for genuine 650bhp
Hi all,
Which head gasket and bolts can safely handle 650bhp
I have tried with, shimmed block and cylinder head with 3 layer cometic and ARP, the engine has run 410bhp i 4 years fine, but after an upgrade to 650bhp, the gasket gives up above 500bhp, air i the water.
Please only answer if you have experience with this or have tried it yourself.
Old Oct 11, 2009 | 10:58 PM
seriesoneturbo's Avatar
seriesoneturbo
use a cornflake box and a tube of super glue, it worked for my mates 950bhp 1.1 fiesta triple turbo 4valve steam engine running nos.
Old Oct 12, 2009 | 08:12 AM
LHD220Turbo's Avatar
LHD220Turbo
Originally Posted by sirmark
Hi all,
Assuming you are using a 200 block; is it long studded, or are you using the short ARP head studs?
With regards to the headgasket; i am trying to remember the headgasket MadRod uses in his 800+hp motor.
Old Oct 12, 2009 | 08:36 AM
natehall's Avatar
natehall
From my memory, im sure it was the WRC gasket however Mark had to adjust the timing to keep cylinder pressures down.
Old Oct 12, 2009 | 09:00 AM
grcossie's Avatar
grcossie
4 layer wrc gasket, it`s much better than 3 layer one, or you can o-ring your block
Old Oct 12, 2009 | 04:00 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
We went back to a WRC gasket after failure of a Cometic gasket.
We decided against using 120ron fuel because it would take so much more ignition that cylinder pressures were too high for safety. Its a real compromise at these levels.
Old Oct 12, 2009 | 05:21 PM
mudlark's Avatar
mudlark
Smile
4 layer wrc headgasket buy it from mountune
Old Oct 12, 2009 | 06:29 PM
sierra cossie's Avatar
sierra cossie
10 long studs and wire ringed, worked perfect on my engine with 767hp.
Old Oct 12, 2009 | 08:03 PM
sirmark's Avatar
sirmark
Which of theese two solutions are the most bullitproof ?
10 long studs from mike rainbird and Mountune 4-layers WRC gasket
or
Long studs from Reyland and Mountune 4-layers WRC gasket?
My piston CR is 7,5:1 and I'm concidering bying a new set of pistons in CR 8,5:1 so I won't need as aggressive ignition map......
The best pump fuel we have in Denmark is Shell V-Power 99 ron
Old Oct 12, 2009 | 08:27 PM
LHD220Turbo
i know reyland long studs use a smaller bolt top so you can get a smaller socket to torque them up
i'm not sure if Mike's is the same
send Martin a PM on here
if buying new pistons; i would go with CP pistons as the manufacture
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
coscor86
Sep 20, 2015 01:21 PM
pie-face
Sep 15, 2015 10:43 AM
Chopshop85
Sep 12, 2015 06:42 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
