breather fitting on a 4x4 saff???
Old Oct 5, 2009 | 11:07 PM
crash&burn's Avatar
crash&burn
Default breather fitting on a 4x4 saff???
please help i need to know where all 4 pipes go on the breather and which order i get the top ones sort of 1 rocker cover 2 kidney then its the two bottom ones a big and a small is the small a oil return to the sump? is this on the turbo side? then it's the big one where does this go? sorry to sound thick any help would be great thanks
Old Oct 6, 2009 | 06:42 AM
nellyscossy's Avatar
nellyscossy
right about the top ones
the big bottom one goes along the chassis leg to atmosphere
the smaller bottom one goes round under the turbo (slightly towards the rear of the block) you should have a blanking plug in the block
people argue that the oil return should be lower than the oil level itself but on a standard sump there is no provision for this so the side of the block it is!!
Old Oct 6, 2009 | 06:21 PM
There's no argument about the oil return if fitted, if it is above the oil level it is a breather, it oil fumes pressure will come out the engine and up the pipe, whereas below oil level it cannot act like this, the lack of a return can be easily overcome by using a sump plug return.
Old Oct 6, 2009 | 06:33 PM
crash&burn's Avatar
crash&burn
thank you for both your replies the thing that stumps me is surely with the large bottom one going to atmosphere there will be no oil for the little one to return it would drain out the bigger one first? is a spec r larger tank that sits on the flitch (header mirror) a better option sorry for all the questions
Old Oct 7, 2009 | 06:43 AM
nellyscossy
the breather is divided into two inside ,there is a fine mesh that catches the mist, the oil then gathers and runs down the return pipe, the big bottom pipe is designed to go to atmosphere so it should never be blocked/restricted, i've had a breather on all my motors and i cant say ive ever noticed oil coming out the big pipe, just a lovely smell!!
Old Oct 7, 2009 | 08:13 AM
The breather isn't divided into two, the large pipe isn't just welded to the outside but in fact goes all the way nearly to the top of the tank, oil being heavy falls and runs out the small pipe which is just on the bottom of the tank, and doesn't protrude in all the way like the large one, there should be deflector plates inside that buffer the oil/mist and allow it to drain.
Old Oct 7, 2009 | 10:11 PM
crash&burn's Avatar
crash&burn
that explains it thanks guys it makes sense now cheers
RUBY123
Oct 22, 2023 12:04 PM
FlashRS
Sep 14, 2015 12:36 PM
mrmann
Aug 20, 2015 11:24 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
gingerturbo
Aug 18, 2015 07:58 PM
