big problem with airtec intercooler
Old Sep 29, 2009 | 07:25 PM
luxembourgrst's Avatar
luxembourgrst
Default big problem with airtec intercooler
well i have fitt the two radiator from airtec but i can t put my spec 90 bumper back
i can t put more back my water radiator
i cant put the water cooler more back because it s touch the turbo wastegate
im scared because i changed in my restoration the front panel...
Old Sep 29, 2009 | 09:05 PM
G420 DEL's Avatar
G420 DEL
seems to be the way with a front mount cooler. it wasnt made to take a cooler so big so you've got to make it fit.
Old Sep 29, 2009 | 09:10 PM
andy130's Avatar
andy130
jigsaw i think mate
Old Sep 29, 2009 | 09:18 PM
G420 DEL's Avatar
G420 DEL
pic borrowed off here (thread called "lets see your s2 rs turbo's") looks like he got same cooler and the bumper still looks like it hasnt been messed with. so assume he's made it fit further out, added spacers to the mounting bolts. but only thing with that is the line around the front wheel arch.
Old Sep 29, 2009 | 09:28 PM
TOMO's Avatar
TOMO
put the jigsaw down and put the fans on the front of the intercooler, then only slight trimming is needed to the bumper
Old Sep 29, 2009 | 09:48 PM
RSmark84's Avatar
RSmark84
i fitted all 3 rad, cooler and I/C same as what you've got and i can confirm from your pics your rad isnt pushed back far enough, the minium gap you can have is 1cm from the turbo to the rad, get everything off including the rad and route the loom backwards off the crossmember and then your rad will go back abit. Easy stuff.
Old Sep 29, 2009 | 09:53 PM
RSmark84's Avatar
RSmark84
heres some pics, ignore the cut across the bumper i thought it might needed to be done but it didnt.
RSmark84's Avatar
RSmark84
oh one last thing i used kenlowe fans, better quality than the other ones.
Old Oct 3, 2009 | 12:13 PM
luxembourgrst
well i can fix my bumber but the bumper touch the radiator
are there no spacer between the front panel and the bumber?
i think it is good now but the inside of the bumper touch the intercooler
Old Oct 4, 2009 | 03:02 PM
luxembourgrst
up
Old Oct 5, 2009 | 02:46 PM
luxembourgrst
up
Old Oct 5, 2009 | 06:21 PM
Antti O's Avatar
Antti O
I put some washers between bumper and car chassis and that solved my problems with airtec ic / rad. I cant take pictures now because my car is in winter storage but later in this month.
Old Oct 6, 2009 | 10:09 AM
luxembourgrst
thank you im going to do the same
Old Oct 6, 2009 | 12:12 PM
Antti O's Avatar
Antti O
Here is some pictures about front bumper from recent photoshoot if you would like to look bumper position
http://s186.photobucket.com/albums/x...toshoot092009/
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
simonmcf
Sep 22, 2015 08:40 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
