problems with my escort 1.8 gti
Old Sep 21, 2009 | 04:07 PM
bryn19's Avatar
bryn19
Exclamation problems with my escort 1.8 gti
right just got a 1.8 gti on a R plate. im having problems when i try to put my foot down there is no power and just seams to stop going but if i drive it soft its ok till it hits 5-6 rpm then its dead what could it be oh and head gasket is fine thanks. plz help tell me any thing that it might be plz
Old Sep 23, 2009 | 07:33 PM
forevaford's Avatar
forevaford
maf sensor?? cat blocked?? airfilter blocked?? 1 of them 3 i recun
Old Sep 23, 2009 | 08:02 PM
STeve's Avatar
Super Moderator
may even be a air leak or dodgy throttle body or tps
Old Sep 24, 2009 | 08:03 AM
bryn19's Avatar
bryn19
ive done it!!!! what a mission that was i tryed,water temp sensor,air temp sensor,coil pack,leads and plugs but it turned out to be the air flow sensor. i got one from the local scrapy for a pound woop ive been looking on the forums and theres been loads of problems like ive had im glad it didnt cost me much.now just got 2 get the ecu reset 2 clear the errors thanks guys
Old Sep 24, 2009 | 08:15 AM
STeve's Avatar
Super Moderator
The joys of owning and running a GTI 24/7
Old Sep 24, 2009 | 08:19 AM
bryn19's Avatar
bryn19
well ive only just got this one so its all new for me there fast but not sure if it as quick as my old 306 xsi but i will find out wen i get a open road soon but my gti is standard at the moment dont know wat to do 2 it yet any ideas lol
Old Sep 24, 2009 | 08:27 AM
STeve's Avatar
Super Moderator
The GTI label was just a gimmick by ford as it only meant bodykit and half leathers apart from that its just a Si ,without going silly moneywise a good quality exhaust and air filter will improve things and maybe a upgrade to a 2 litre throttle body and maf will add a couple of bhp,if you want to spend money on it then I would go for the 130ps set up of cams etc from some of the older Si models ,as the 2 litre conversion is not worth the aggro as you will still be sub 150 bhp anyway,down to money fella as you can turbo them but you wont get much change out of Ł1000 for that install ,heres mine below at this years FITP
Old Sep 24, 2009 | 08:36 AM
bryn19's Avatar
bryn19
just need 2 sort bottom arms and a bit of rust first did u have any problms with rust with urs?
Old Sep 24, 2009 | 08:41 AM
STeve's Avatar
Super Moderator
I now break escorts and mainly GTI/RS2000 models and the main cause for me breaking them is the owners give up on them due to chassis rail rust and rear wheel arch issues,I was lucky with mine as I dont have this issue but then again I would have not bought it if it did,but yes its very common and for some reason the RS2000s are far worse than any other escort for some reason,as for bottom arms I suggest you dont buy these cheapo ones from motor factors or ebay as they are pure rubbish and wear out mega fast,go for genuine ford around Ł50 a side but you wont regret it,hope it helps matey
Old Sep 24, 2009 | 08:45 AM
bryn19's Avatar
bryn19
ive only got a little on rear arches and a tiny bit on boot i just wana do it b4 it gets 2 bad if u know wat i mean? is only had 2 owners both ladys lol it was good 2 have some power last night
Old Sep 24, 2009 | 08:49 AM
STeve's Avatar
Super Moderator
The GTI is a better looking escort than most in the range hence why so many copy the bodykits and fit them to their non GTI/RS models .my pet hate is people that fit a bodykits then badge their car up a GTI it does make my grin,as the log book (v5) does not agree,best of luck with yours fella ,may see you at a show next year,I normally show with ukford or eodc but who knows for next year
Old Sep 24, 2009 | 08:58 AM
bryn19's Avatar
bryn19
yea i would like 2 come to that have u got any details on it please ?
Old Sep 24, 2009 | 09:03 AM
STeve's Avatar
Super Moderator
you can sign up on www.eodc.co.uk free of charge and the same with www.ukfordoc.com and as soon as 2010s shows list goes up all you need to do is speak to relevant events organisers of both sites,there are plenty of other escort sites about but most only want your money and membership fees and are not interested in you.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 1, 2015 06:48 AM
