FRST Headgasket advice please
Old Sep 18, 2009 | 08:40 PM
Robs Frst's Avatar
Robs Frst
Unhappy FRST Headgasket advice please
Headgasket let go after taking the FRST for a run. Floored it then car noticed a big cloud of steam, water coming from my exhaust.
The car then went into limp mode, luckily i was close to my mates, I eventually reached his.
Had a look under the bonnet oil filler cap has got a mayonnaise look to it (Headgasket).
Started to take the head apart to get it ready to be skimmed and inspected. The car runs 200 bhp, Is the standard Ford gasket still okay for this power? What head bolts should I go for?
Thanks for any advise.
Old Sep 18, 2009 | 08:48 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
ford head gasket mate all the way
Old Sep 18, 2009 | 09:08 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
payen/Ford headgasket will be fine, i ran over 200bhp on my zvh/cvh turbo's and never had a problem, unlike bga ones.
Old Sep 18, 2009 | 11:42 PM
Tomm's Avatar
Tomm
ARP Headbolts are what i would go for mate!
Old Sep 19, 2009 | 12:07 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I wouldn't, not on a CVH!!
Old Sep 19, 2009 | 12:16 AM
Tomm's Avatar
Tomm
really? I never knew that!
Why is this? I always thought they dealt with bigger BHP figures better?
Old Sep 19, 2009 | 10:34 AM
Christian and Beccy
#1 in Spelling Club
It's not quite that simple. The CVH has a cast iron block and Alloy head. The reason for stretch bolts is to deal with the differential in materials and the way they heat up and cool down.
I began to have problems with the head lifting at 350bhp on the old set-up, but until then, they were and still are fine (although at this moment, I'm only running 320bhp).
Old Sep 19, 2009 | 10:45 AM
Karlos G's Avatar
Karlos G
Balls Deep!
+1!
Old Sep 19, 2009 | 05:13 PM
Tomm's Avatar
Tomm
oh right thanks for that! I honestly didnt know that!
Learn something new every day. So are you running OEM spec stretch bolts at 350brake?
thanks for that, as you can probably tell i am very new to CVH's
Old Sep 19, 2009 | 05:46 PM
Christian and Beccy
#1 in Spelling Club
Yes, OEM Bolts and Gasket.
Old Sep 19, 2009 | 05:53 PM
crazycage's Avatar
crazycage
the thing is tho loads of engines run much more power than the cvh with a cast ally head and a iron block and run arps ,so i wonder why there not that good on the cvh.
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
