problem with kms ecu
Old Sep 14, 2009 | 06:11 AM
1cosworth's Avatar
1cosworth
Default problem with kms ecu
morning lads.got a guestion about kms programming.cant find someone who can make the kms work with the idle control valve from a 4x4 coosy.any ideas?
Old Sep 14, 2009 | 04:01 PM
You can do without the iscv anyway, my emerald ecu runs it but it's so good from stone cold that it doesn't seem needed not even last winter.
Old Sep 15, 2009 | 05:53 AM
1cosworth's Avatar
1cosworth
the problem tabetha is with the revs.using the valve with the kms lifts the revs to nearly 2000.nobady cant find a solution to this so they just unplug it and it cant hold the revs
Old Sep 15, 2009 | 12:38 PM
You can set the tickover speed from the base idle screw on the underside of the throttle housing.
You could just take off the iscv, block the bypass hole underneath it with a wood dowel or similar, and on the air passage entry for iscv in the housing before throttle plate, then just adjust iscv, or just leave iscv there and adjust with it disconnected.
Old Sep 15, 2009 | 12:53 PM
1cosworth's Avatar
1cosworth
Default kms
thanks a lot tabetha im gonna try it like that
Old Sep 16, 2009 | 12:38 PM
No probs matey, loads running around with no iscv.
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
tib2220
Sep 14, 2015 12:33 PM
dms04
Sep 11, 2015 01:57 PM
